first child 84 944
Strange noise around drive line while idle
After my 944 has been driven some and warmed up, when i disengage the the clutch amd put in nutral i hear a odd noise from under the car somewhere from shifter to rear end. It doesn't make this noise when until its been driven around. Any help would be much appreciated. Thanks hope everyone has enjoyed your so so warm and not so wet summer lol.
AFM #725
Could it be something exhaust related? wild-guess. I had a rattling exhaust that would randomly make odd sounds
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Banned
Throwout bearing or exhaust
first child 84 944
Thank you all for your suggestions! I was also afraid it could be the throw out bearing too. I believe i may have dried it out when my clutch disc got stuck. Only after i replaced the master and slave did i find out lol. Well would anyone happen to know if it can be regreased by chance?
You will have to remove it either way (not really regreaseable) just replace it.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Banned
I regreased my throwout bearing but it was a bit of a pain.
Also i was just thinking and this could be your torque tube bearing also. Check clarks garage for how to check and test. |
AFM #725
I don't think the TT bearing would make idle noise. Mine doesn't. Only a little under load
Banned
Torque tube could absolutely make noise at idle with the clutch engaged because its still spinning
AFM #725
I see
first child 84 944
I gotcha! Thanks a million. But when the clutch is engaged the noise "light cluncking" goes away. When its out of gear is when i hear it. But not all the time that's what's making me scratch my head some. Thank you all so much for the input!
Banned
When i say engaged what i mean is clutch out and in neutral. When you press the clutch to the floor the noise goes away is what im getting from your post. If the noise goes away almost instantly after pressing down the clutch pedal then its almost definitely the throwout bearing. Mine does exactly that and as far as im concerned its harmless.
Anecdotally ive heard a brand new throwout bearing has ended up being even louder than the old one for some people on the forums. |
porscha
only way is to ur a stetoscope on TT or Clutch housing
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh Canada , Quebec |
AFM #725
I could be wrong. But I would think it's more likely the TO bearing then. Because the TT bearing would probably make noise under load.
Banned
Gawernator got it right.
porscha
Only way is the listen maybe it's both keep us posted good luck man
torque tube 90 %
i rebuild myself about 4 of this.The maximum noise is at idle(the car dont have noise from wind and heard better) and on deceleration-pedal gas release like a zzz-zzz-zzz-zzz or ratle-ratle-ratle... in every gear but in the first two better to heard-i think the same reason-wind. is a big procedure for rebuild and a little tricky but if you do a clutch job is hight racomanded,you will need from 2 to 4 hours to rebuild it
porsche 924 carrera gt 90% ready porsche 944 NA 86' half 951 951 full project for 944 chrysler 300M 6 x 924 and 944 canibalized or death |
Toofah King Bad
I am leaning toward TT bearings. Easy to test. If the throwout were noisy, light clutch pedal pressure (running, in neutral) should make the noise change. If not, torque tube.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
