cooling fans
Hi, before I take the fan relay apart I'd like to ask for confirmation of the following symptoms I'm getting------as soon as ignition is turned on the fans start,(fast) I have unplugged the thermofan connector (ign on) fans are still running(fast). Linked terminals 2 &3 on thermofan switch connector (ign off), fans run but fast. Looking like relay, your views please.
944s2
Old 08-12-2012, 11:52 AM
9FF 9FF is offline
9FF's Avatar
Relay is a quick swap to confirm but my educated guess is if your fans are always running fast your puck resistors are toast.
Old 08-12-2012, 01:24 PM
I've not got a spare relay to try, and please explain more about these resistors.
944s2
Old 08-12-2012, 01:33 PM
9FF 9FF is offline
9FF's Avatar
Two large ceramic "puck" resistors are located behind the glovebox or under the fan cowl in the engine bay on later cars. They control fan speed on both the fans. They either work (fans run at low and high speed) or they don't (fans on high speed only).
Old 08-12-2012, 02:14 PM
Thanks for that, will check them out before going further.
944s2
Old 08-12-2012, 02:18 PM
ernie9944's Avatar
+1 (see pic of how bad the connections can corrode ).
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 08-12-2012, 06:34 PM
Thanks for the picture, very thoughtful of you
944s2
Old 08-13-2012, 01:51 PM
9FF 9FF is offline
9FF's Avatar
You would have got one from me but mines an 86 with the resistors behind the glovebox. If yours is the same you have to remove the glovebox and get into some extreme yoga position to access them GL
Old 08-13-2012, 03:25 PM
No problem, I'm grateful to you for the location info you posted, I have an '89 so a little later.
944s2
Old 08-14-2012, 05:11 AM
CatsEyes's Avatar
Hey 9FF,
I have exactly this problem, on my 1986 RHD (Euro-spec) 944.
There is a clicking noise behind the glove box (on the left-hand side of the car), when the fans succeed or fail in going to low speed.
I'm presuming this is the same layout as for LHD cars, but on the other side.
Do you have any more precise information about where the 'puck' resistors are? Is there a diagram somewhere? Perhaps my yoga skills are wanting, but I'm struggling to locate them...
Thanks,
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II'
1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten
'Hell is previous owners.' (anon.)
Old 08-16-2012, 02:15 AM
9FF 9FF is offline
9FF's Avatar
I don't know for sure where they are on the 86 RHD models but I will guess they are somewhere under the dash attached to the firewall. They moved them from inside the car to under the hood on 87 models. Search with a bright flashlight for this:
Old 08-16-2012, 04:04 AM
Well I've been searching all morning for mine! They're not under fan cowling despite being a post '87 car. Maybe the s2 is different, I presume they must be fitted to this model? Checked under the glove box just in case. It's right hand drive so will start looking at the other side.
944s2
Old 08-16-2012, 06:11 AM
CatsEyes's Avatar
[QUOTE=9FF;6915777]I don't know for sure where they are on the 86 RHD models but I will guess they are somewhere under the dash attached to the firewall. /QUOTE]
Thanks, 9FF.
The sound is definitely coming from behind the glovebox. But, as you say, it's tight in there. Not easy to see them.
I'll have a better look tomorrow. If I dig the little critters out, I'll take pics for the RHD folks.
Old 08-18-2012, 05:03 AM
CatsEyes's Avatar
Found 'em.
9ff's intuition was right.
On RHD cars (at least '86 and earlier) you'll find them on the driver's side, under the steering column, on the right hand side (actually to the right of the firewall).
Can't find anything wrong with mine: they look almost factory.
Ah well, more troublshooting...
Old 08-24-2012, 03:50 PM
Banned
That clicking sound by the glovebox is your relay 'firing', for lack of a better term. Everything inside on a rhd is reversed but under the hood the relay/fuse box is still in the same place.
Old 08-24-2012, 05:12 PM
Updating this thread to inform that an '89 Rhd s2 (which Im' calling a late car) car also has these resistors to the right of the steering column underneath. The wires on mine look pretty sound, wondering if the actual resistors are dead. Is there a test?
944s2
Old 08-30-2012, 01:53 PM
Toofah King Bad
Rasta Monsta's Avatar
Well, you could always check the resistance.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-30-2012, 07:23 PM
Well I suppose I asked a silly question
944s2
Old 08-31-2012, 08:34 AM
CatsEyes's Avatar
Thanks, fwayfarer.
I'd already replaced the relay, though, so this is puzzling. Maybe I should check the wiring below.
Old 09-01-2012, 12:45 AM
Hoover, your cooling fan relay is bad. The resistors only come into play when the relay wants the fans to run at slow speed. If you want to go through the system, I have created a diagnostic procedure that is included below.
During normal operation, and you have the factory rated thermostat, the coolant temperature gauge should read at or near the lower white line (80 degrees C) and will creep up to the mid-point between the upper and lower white lines when sitting still in traffic. The upper white line represents 100 degrees C. If the temperature normally runs above the mid-point, you need to investigate immediately.
There are several temperature ratings of the thermo switches, so it is hard to say at what point they should turn on for your car. If they are not both running at high speed when the temperature is above 90, you might have a problem.
The fans are controlled by the cooling fan relay which is in turn controlled by the thermo switch, and the a/c system. Whenever they are closed, both fans should run at the same speed at the same time. If only one is working or you only get high speed operation, there is a problem.
You should always have power available to the relay, so the fans can run at any time. Remove the cooling fan relay. It is the large rectangular silver relay in the back of the panel. Check the diagram on the fuse panel cover for the exact location. All of the following checks can be made at the fuse panel. You will need a bright light to see the markings on the fuse panel.
1. In the Bosch world, a terminal designation of “30” means it is un-switched battery voltage. Check for voltage at positions 30 M1 and 30 M2. You should get 12v + at both positions. If no voltage, check the wiring from the battery, the connections to the fuse panel, and the fuse panel itself. You will have to pull the fuse panel up, but disconnect the battery before messing around under the fuse panel.
2. Check for continuity between ground and the temp switch positions "TS" and "TF" on the fuse panel. If you have continuity, the thermo switch is calling for fan operation. If the car is cold, the thermo switch is bad.
3. Fabricate a jumper wire with flat blade connectors on each end, and a 20a fuse in the middle.
4. Connect the jumper between M1 30 to M1, the drivers fan should run at high speed. If the fan does not run, check for voltage in the connector at the fan motor, if you have voltage but the fan does not run, replace the fan motor.
5. Check the passenger fan by connecting the jumper between M2 30 and M2, the passenger fan should run at high speed. If not, the same drill.
6. Next connect the jumper between M1 30 and V1, the drivers fan should run at low speed. If not the resistor or wiring is bad. Check for voltage at the radiator fan connector and then check the resistance across the resistor.
7. Next connect the jumper between M2 30 and V2, the passenger fan should run at low speed. If it does not run, check the wiring and resistor.
If the car is still running hot and the fans are working properly, you have other issues, like a clogged radiator, water pump failing, air bubbles, bad thermostat, or a bad head gasket.
The other positions on the fan relay are:
X = battery power to the logic board in the relay
31 = Ground for the logic board in the relay
AC = AC freeze protection switch
Keith Belcher
'87 951 nautic/cancan
Old 09-01-2012, 05:47 AM
