944tothefloor's Avatar
O2 sensor questions - Need quick help
I am on a march to pass smog after tripling all the maximums. I have about 2 days!
I've searched this but couldn't find what I needed. I called a dealer and learned that my 1986 951 has a 3-wire o2 sensor because it's heated. Ok. So no one in my area has one in stock until tomorrow. Obviously I need to stick with a 3-wire part right? If so, I'll have to wait to tomorrow. How easy is it to do by oneself? I can't weld. Should I let a shop do this?
Also, I need a new cat. Is it common to do without the resonator? And does this make the exhaust bad and load?
Thanks!
Old 10-18-2012, 02:09 PM
That Guy
Techno Duck's Avatar
Get a universal 3-wire O2 sensor, you cut the old O2 sensor off and splice the new sensor on with the old connector. Bosch 15726.. should be in stock at any auto store. Its very easy to do.
Welding is not needed to replace, only requires a wrench (7/8" or 22mm) to get it loose. The sensor is located just before the turbo inlet on the drivers side; basically follow the exhaust pipe that wraps under the oil pan up on the drivers side, look straight up and you will see it. The only difficult part is routing the wire, the original O2 sensor wiring fits under a few heat shields and ends up inbetween the intake manifold and the firewall.
The 951 will sound fine without the resonator, n/a's are really the only ones that suffer that problem.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-18-2012, 02:53 PM
Proprietoristicly Refined
John_AZ's Avatar
The new universal Bosch O2 sensors have a "Posilock" connection feature that eliminates any failure in the connection.
The current universal was Bosch 15725 and has been updated to the 15735
Actual install info:
Failed emissions with high NO
O2 sensor
If you buy a older style 3 wire Bosch without the "posilock" connection, DO NOT SOLDER the wires together. Crimp wires together in plastic covered electrical connectors.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-18-2012, 04:16 PM
Thanks both of you. I'm going with a bosch 3-wire, after all. I think it's the 15735, but not sure right now.
Old 10-18-2012, 04:51 PM
I used this was not thrilled with the connectors.
O2 sensor
John
86NA944
Old 10-18-2012, 04:57 PM
one of gods prototypes
bell's Avatar
the connectors aren't too bad to deal with, use a quality pair of wire strippers (not those auto ones)....and.....don't solder them
Brought to you by Carl's Jr.
Old 10-18-2012, 05:10 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If you replace the cat, remember to get the one that's specifically for the California model or you'll bust the test again.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 11-02-2012, 08:30 PM
