Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Injection- This is about proud
Hi,
Like some of you already know, I have problems with my engine because here don´t exist an specialist in this old cars and the only one that I can find is and old man retired that continuosly travel but he will return and will be finish the job.
But I like to job in the car !
Then I will try to fix by myself until he returns and have fun doing myself.
Then,
I found some air or vacuum lines lines disconected and I can´t find where will be there connect it.
Then I believe that the better way to know id taking out the injection.
And by the way look the intake valves to know how I need to install the timing belt.
And by the way the way check the air valve.
questions
1.- Obviously when the piston 1 is on tdc ( combustion and exhaust) the intake valve in piston 1 will be closed.
Then with the piston 1 in tdc and the cam in tdc what piston # intake valves need to be open.
This to know if I´, 180° off.
Old 06-13-2002, 03:46 PM
