16vCorey's Avatar
Another no-start. Anyway to test the DME on an '86 944?
So I'm working on a car that someone already started working on. It belonged to a friend of mine, and one day it wouldn't start. He was going to start by checking the reference and speed sensors (I gave him some spares) and he broke one in the bracket. That's where he gave up. Anyway, I got the bracket off and the old sensor out, set the sensor height, put two new sensors in, and no start, no tach bounce. I tried switching the sensor plugs (since it was all apart when I started working on it) and still got nothing. Jumped the DME relay, and the fuel pump kicks on, but still no tach bounce. So now I think that I'm narrowed down to the DME. Am I missing anything?
Old 11-17-2012, 12:40 PM
There is a way to check the reference sensors to see if they are good or not. You will need a meter. Clarks garage will tell you how.
Old 11-17-2012, 02:25 PM
16vCorey's Avatar
I figured it out. I accidentally swapped a bad sensor with another bad sensor. I didn't want to use my brand new ones yet because I was told by the previous owner that he "may" have dropped a bolt into the bell housing. I was using some used "good" sensors, just in case that bolt decided to make it's way up to the sensor and break it. I put the new sensors in and I had tach pulse, but still no spark. I popped the distributor cap off to find that the rotor was broke in half! Swapped rotors and it runs like a charm!
Old 11-17-2012, 02:46 PM
Proprietoristicly Refined
John_AZ's Avatar
Great work.
Check for the missing ?? bolt, you're on a roll.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-17-2012, 03:30 PM
AFM #725
Gawernator's Avatar
Quick question. Is it okay to cover the bell housing hole with a piece of gorilla tape?
Old 11-17-2012, 06:26 PM
John_AZ's Avatar
Sure,
It may look better to use the rubber cap though.
Product Information: 931-116-177-00-OEM
OH, you meant the hole near the reference sensors----yes again
John
Old 11-17-2012, 08:44 PM
AFM #725
Gawernator's Avatar
Doesn't the clutch inspection cover "fall out"?
Old 11-17-2012, 08:51 PM
In the Fires of Hell.....
kdjones2000's Avatar
Not if you silicone it in....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-17-2012, 11:00 PM
16vCorey's Avatar
I should add the the bad sensor passed the resistance test, but I don't have an oscilloscope so I couldn't fully test their operation. I guess I'm just saying let that be a lesson, even if it passes the resistance test, don't rule it out!
And no, I never found that bolt, so who knows if it was ever actually in there. I guess I'll find out when I do the clutch!
Old 11-18-2012, 07:16 AM
