can of Ate brake fluid
what is the inner diameter of the cap from a 1L can of Ate brake fluid?
alternatively, is there a cap of similar size out there?
Old 11-19-2012, 11:53 AM
Tcrate's Avatar
Not a clue but curious why do you ask?
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 11-19-2012, 03:32 PM
if the container's been open this long...it's already absorbed enough water.
unless u've saran wrapped it or something.
Old 11-19-2012, 03:41 PM
Generally, if you open a can or bottle of brake fluid for a brake project or just to top off the fluid in your car, that can is good for about 6 months if the cap is on tight. If the cap hasn't been on the fluid, I would say anything over a few weeks would compromise it.
Old 11-19-2012, 04:08 PM
Proprietoristicly Refined
John_AZ's Avatar
How did shelf life become the answer?
But "Truth or Myth?"
I do not have the answer to inner cap diameter.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-19-2012, 04:20 PM
AFM #725
Gawernator's Avatar
I can measure when I get home. I have an unopened liter of Super Blue
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-19-2012, 04:21 PM
FrenchToast's Avatar
The real question is what is the ratio of the flange depth at the bottom of the cap, to the angle between each knurl in radians.
That. That is the real question.
Take care!
_________________________
Y'all have a Happy Thanksgiving!
Old 11-19-2012, 10:08 PM
AFM #725
Gawernator's Avatar
Set calculator to degree mode, it's easier!
Old 11-19-2012, 11:04 PM
ultimately, I want to purge it with something that lacked moisture, to improve storage. I figure I'd need to cut some holes in the cap for some tubes. knowing how much space there is to work with before opening the can will minimize exposure to air, and I want to use a freshly bought can instead of having it sit around., and I don't have any junk cans laying around.
Old 11-20-2012, 04:38 AM
Originally Posted by Gawernator View Post
[...] I have an unopened liter of Super Blue
I appreciate this offer, but I hope its clear that a rough estimate is OK - don't sacrifice a fresh can for this!
Old 11-20-2012, 04:40 AM
wilkrod's Avatar
Propane
If you are that concerned about it, just take a propane torch, crack the valve, point into the fluid can for a few seconds, put the top back on.
The propane will displace any moisture/air.
Just don't light it.
Jeff
Old 11-20-2012, 05:19 AM
