tnporsche's Avatar
no fuel has spark
A 83 944 na that's been sitting about a year. It ran when parked. If I shoot carb cleaner in the TB it will run for about 5 sec, SO that tells me its firing right?
I removed the cap at the end of the fuel rail, only drips out. nothing when cranking. Broke opened larger line coming to fuel rail and same thing.
Ideas?
which relay is the fuel pump relay on the 83 944 ? so I can force it to run
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 11-19-2012, 12:32 PM
16vCorey's Avatar
Not sure about the relay location, but I'd crawl under it and see if it's getting power while someone cranks it over. If it's getting power, you need a fuel pump.
Old 11-19-2012, 01:26 PM
jpk jpk is offline
It's relay #2; second one in from the left side on the top row (furthest from the fuses). It's really two relays in one; one side controls power to the DME (engine computer) and the other controls power to the fuel pump based on a signal from the DME.
Check Clarks garage - there should be instructions on how you can make a jumper to test.
-John
'94 968 Iris Blue
'85.5 944 White - Rally Cross and wrenching practice
'84 944 Gemini Grey (gone, but missed...)
Old 11-19-2012, 01:40 PM
tnporsche's Avatar
thanks, I checked and it has power at pump while cranking, drained tank fuel smelled bad, prob caused pump failure I guess. I have pump on bench if hit it with power in vise it just buzzes. I turned it up so it could soak with cleaner but im betting needs pump even if it runs as it not reliable I suppose.
Anybody have a link to a low cost pump or replacement ?
Lowell
Old 11-19-2012, 02:16 PM
