-   -   Stock replacement front springs for S2 without lowering? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/718167-stock-replacement-front-springs-s2-without-lowering.html)
marko 11-21-2012 04:07 AM
Is there no one that has new replacement springs for S2?? I'd just like some #200 replacement springs without lowering or needing spacers.
Rasta Monsta 11-21-2012 08:50 AM
Pelican Parts - Product Information: SP944-220S
marko 11-21-2012 04:02 PM
It says from 1976-88, mine is a 90.
murrayg 11-21-2012 04:35 PM
Won't work on an S2, smaller diameter spring.
cockerpunk 11-21-2012 04:44 PM
also watch out for those springs, i bought them, and they were way way way way too short. pelican said that they requires some spacers - 80 bucks.
might as well just get ground control front coilovers for that kind of money.
ernie9944 11-21-2012 05:53 PM
Why don't you opt for a pair of (Weltmiester 250 pds) from Automotion,they will only lower your S2 approx 1.5" front which is not extreme.Then you could lower the rear 3/4" by adjusting you camber plates.This will be the most inexpensive way of doing thing.Agree that that ground control front coilovers are nice but it will cost more.:D http://forums.pelicanparts.com/uploa...1353548986.jpg
Weltmiester 250 pds
RedBaron 11-21-2012 08:16 PM
Get a set of used 951 (87+) shocks and Weltmeister springs with spacers. That's exactly what I did. The S2 shocks require a different diameter spring.
marko 11-22-2012 02:56 PM
I already have new struts installed with the original springs. I still have a lot of roll when cornering. I'm guessing my springs are probably worn out after 250k miles. Control arm bushings are definately worn out, but I have some powerflex bushings ready to be put in. I just need some new 200lb springs that will fit, 250lb might be too harsh for a daily driver. Used suspension parts are out, I've gone that route too often with disappointments.
