Anybody use an aftermarket tach?
Talking about an early car of course, because if the gauges are a common size a different one should fit right in. I currently have an early 924 tach and it behaves like the needle is too heavy or something, plus I don't think it's accurate. Can I grab one from autozone? Lets see some pics!
What cars came without tach's? The earliest 924's I've seen even had tach's? I'm not really any help, but am curious.
1983 944 This was probably posted from my phone, so please excuse any typos. |
Did I imply there are some cars that came without them? I didn't mean to, as far as I know they all have one
So you want to replace your OEM tach with something you hope is more accurate?
AFM #725
meister member
I have always like the early tachs due to how they swing down clockwise as the revs climb. If I was in your position I would look for an early replacement tach from a parts car.
Speedy ![]()
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Not this.
Anyway, I second the sourcing a used original tach as well. As for an aftermarket tach, IIRC the original tach is a touch off, about 200 RPM. Forget if it's north or south. If you want aftermarket, get a good unit such as VDO, Borg-Warner, Autometer etc. Don't know if Lucas still make gauges? VDO has supplied gauges for Porsche probably at least since the sixties. They likely still do. BTW, I think the only Porsche that came without a tach would've been some early 356's. And probably the Porsche tractors, too ![]() Take care! |
AFM #725
Pssh you don't need a tach or speedo. Just listen to the engine!
I've used a few different ones. One racecar (not mine) was fitted with some aftermarket POS Autometer or whatever. Worked, just not nearly as good quality as the stock VDO gauge. We later scrounged a replacement stock one and used that for a while, till it blew up (did I mention the car had a wiring problem?). These were on early 924's.
I definitely would recommend sticking with stock, both for quality and looks. Both racecars eventually ended up running AIM Mychron3 dashes/data loggers, which also have tach functions. My 924 racecar still has it, and it's a badass piece of equipment. Programmable shift lights and all. But not really suitable for a street car: ![]() Oh, not trivial to install (if you want the speedo to work), needs to be mounted somewhere, and did I mention it costs upward of $1200? Crappy pic of the shift lights in action... ![]()
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
Hmm, not looking to spend $1200 haha, but I want to try an aftermarket one. I didn't say my tach was bad, or maybe it is, but all the stock early ones are slow and they swing a lot. I'm on my second stock one
AFM #725
Never had a problem with the tach on my '83, now the fuel gauge is a different story.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
I have problems with my trip and the total kilometer. The main shaft slips on the number wheels, i tought that the problem were in the shaft gear that slipped and I glued it to shaft but I think the shaft is moved from its place now..
Any ideas?
white 81 924 |
AFM #725
Try this? Odometer Repair
Maybe you need a blower, to make that tach swing faster?
Hah, or a different car?
Just so everybody knows what I mean, Turbocharged Porsche 924 acceleration - YouTube See how the arm swings down further that it needs to? That drives me nuts! |
To make sure I understand... are you talking about the lowest rev point between shifts, before clutch engagement?
FWIW... I've found egauges.com (no relation, etc etc) great to work with, and excellent prices - both for gauges and senders, and they carry the full VDO line: VDO: Cockpit Black Series Gauges: Tachometers - In Dash (electronic) - eGauges.com Cockpit is the stock gauge style for our cars - though I don't see a tach there that wouldn't look too small...
