-   -   Noise from rear of engine (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/723459-noise-rear-engine.html)
gricec 12-12-2012 11:27 AM
I have a 85 944, recently developed a noise from the rear cam tower, head or possibly even clutch area.
There is no noise at idle but when I rev it I get a knocking clicking type of noise for a second.
When cold, if i hold it around 3k rpms i can hear it too.
Its worse when cold but still not present at idle.
I pulled the camtower and found 2 soft lifters replaced those but the noise is still there. I have done a compression test and the #s are fine so I dont thinks it dropped a valve or anything like that.
The car pulls great and isnt missing or anything like that.
I am also not thinking rod bearing as usually they get worse the warmer it gets and i would hear it at idle and I have the opposite symptoms of that.
Am stumped to be honest - would appreciate any help/.:)
romad 12-12-2012 01:53 PM
Could be a restricted oil passage, not getting enough oil to the rear followers.
gricec 12-13-2012 12:58 AM
Possible - guess the cam tower is gonna have to come off again. Its wierd - The noise is not constant for example if I get on the throttle I hear it but if I accelerate gently nothing.
gricec 12-13-2012 11:37 AM
Ha now I feel retarded.
Was an exhaust leak. The last two bolts on the manifold was loose as hell. Tightened them up and no ticking noise anymore.
Oh well a week of downtime waiting for lifters for nothing!:)
romad 12-14-2012 01:42 PM
good catch
