'68 911 / '86 944
Brake question
I drive an 86 NA. I replaced the brake master cylinder, soft brake lines and rebuilt the calipers four years ago. I rebuilt the front calipers and replaced the front rotors two years ago. I use Hawk and Carbotech brake pads. The car is a daily driver that sometimes gets to go to the track for DE events.
I recently noticed the brake pedal very slowly progressing to the floor. The brakes still stop great, but when I sit still (at a traffic light) with my foot on the pedal, the pedal will slowly creep lower and lower. A quick pump brings the pedal back up, but then it starts it's slow progression back to the floor.
Brake fluid level is good.
I assume that the master cylinder is the problem. I have ~ 50K miles of use on the last one. I just want someone to verify my prognosis.
Old 12-27-2012, 09:46 AM
ernie9944's Avatar
first check what we commonly call the carpet cylinder (peel the rubber boot back #13) & see if there is fluid in there,if not check the plugs # 10 at the brake master cylinder they will deteriorate with time causing very small leaks which are hard to spot.This I know because at one time I had to change both (plugs/washer) on my 944.See diagrams
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 12-27-2012, 10:54 AM
