cdc cdc is offline
washer jet problems
I am slowly getting through the small problems with my car. Next on the list is the windshield washer jets, when I pull the lever to work them the wipers move but the pump doesn't work. I removed the pump and cleaned it out as it was jammed reinstalled it and it still doesn't work.
I don't seem to be getting any power to the pump when I pull the lever, any ideas on where to start first? Also the wipers don't reset back to the bottom on the windshield if I let go of the lever I have to hold it until they are close to the bottom and then let go.
Old 12-22-2012, 11:31 AM
AFM #725
Gawernator's Avatar
My washer jets don't work either. My last 944 had a bad pump and I bought an aftermarket replacement off evil bay but ended up putting it on my 86 since I sold the 83. Still doesn't work and I haven't tried to fix it since then, but I'd be interested to hear the solution. I also have new hose to replace the old hose.
Old 12-22-2012, 01:37 PM
dkbautosports.com
962porsche's Avatar
i had the same problem with my 84 944 what it was with that car was the wiper switch on the steering column .
when i put direct power to the washer pump it worked .
but it only came out one washer nozzle that was clogged with wax and crap .
the wipers would work when you just turned them on but not reset only when i pressed the washer lever .
in my 944 race cars i don't use the steering columns from the 944 so i just pulled one of the switches from that column and replaced the one in the street car .
because there are many parts to the washer system you have to go thru the system to just check to see what is going on with your car .
it was the switch with my car but it could be just about any thing with you car .
Old 12-22-2012, 01:48 PM
Mein Gott!
Panzer909's Avatar
If you can hear the pump working, 9 times outta 10 the nozzles are simply clogged. I have to take mine apart about every two years or so to clean them, and you wouldn't believe the funk that gets in there. This is what happens if the car sits for long periods without using the washer fluid - it gets pulpy like orange juice over time.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-22-2012, 04:21 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
If the pump is working, not only clean the nozzles, but also clean the lines...a lot of people put plain water in the washer, and over time, the water gets stagnant and forms pond scum it gets sucked up by the pump and clings to the inside of the feed lines.....once in the lines, it starts growing there too.
If you clean the nozzles and pump but not the lines, that crap will plug the nozzles again. Use only windshield washer fluid or water with a mold inhibitor or vinegar
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 12-22-2012, 04:39 PM
cdc cdc is offline
I cant hear the pump when I try and use them, the pump was also blocked but when I cleaned it out it it still doesn't work. I think its an electrical problem somewhere as the pump does not get 12v when I try and use them. I wasn't sure what to check or if there was any common problems with the washer system.
Old 12-22-2012, 05:27 PM
when I took my pump housing apart to check out the motor, all I found was a rust and a few pieces of brass and broken chunks of metal. So glad the PO kept all the broken pieces together in a shiny and polished housing
Black 1984 944
2003 Land Rover Freelander SE3
Old 12-22-2012, 07:37 PM
AFM #725
Gawernator's Avatar
Lmao
Old 12-22-2012, 08:18 PM
Originally Posted by Gawernator View Post
Lmao
hopefully I will be able to LMAO at sometime in my ownership.
Black 1984 944
Old 12-23-2012, 01:05 AM
AFM #725
Gawernator's Avatar
It was just funny the way you said it. Luckily you can get the pump for about $30
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-23-2012, 01:38 AM
dude...everything I say is either tongue in cheek or genuinely in earnest. If I don't gripe and make fun of my car here I might as well cry. My FB friends are sick of my posts and don't have any automotive knowledge past what the dash tells them(or what they interpret). You guys are my only link to automotive experience with my car. I just taught my 22yr old cousin how to use a circular saw, start a lawn mower, and how to plug a tire. granted he was txting the whole time. but I tried.
Black 1984 944
Old 12-23-2012, 01:48 AM
89-944NA's Avatar
Most common problem is the system getting plugged with pond scum. If your not getting any power to the pump, check relay G15 (headlight washer motor relay). If not that then check wiring and the combination switch.
Semper Fi
Old 12-23-2012, 07:09 AM
Volhv's Avatar
Both my nozzles are broken, and this is what I discovered after taking the pump housing apart...
Gawernator, where did you find it for $20? Any source for the nozzles?
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 12-23-2012, 08:13 AM
89-944NA's Avatar
Pelican Parts: Nozzles $49.25 left $42.00 right (85-91) 924S, 944, 944S/S2, 951 & 968
Pelican Parts: Pump $57.25 (924S/944) 83-87, $37.00 (88-91) 924S, ALL 944
Semper Fi
Old 12-23-2012, 08:39 AM
AFM #725
Gawernator's Avatar
I bought one off eBay and idk who actually made it. This was before I started buying OEM and Pelican
Old 12-23-2012, 10:06 AM
AFM #725
Gawernator's Avatar
I think this is the one I bought: C607 VW Jetta Rabbit Scirocco Audi Fox Porsche 924 Windshield Washer Pump 73 88 | eBay one year warranty
Now there is this one: http://www.ebay.com/itm/Windsheild-Washer-Pump-Fits-Audi-Porsche-Volkswagen-OE-823-955-651-/370621155555?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3APorsche%7CModel%3A944&hash=item564abe08e3&vxp=mtr Only $22 and also a one year warranty
Old 12-23-2012, 02:39 PM
Volhv's Avatar
Oh, my mistake, I was referring to the headlight jets and pump. Those are quite difficult to source.
Old 12-23-2012, 04:00 PM
89-944NA's Avatar
Also available from Pelican Parts:
191-955-681-M44 Headlight washer motor $65.00
911-628-071-01-01C-M100 Headlight washer nozzle $15.75ea
Semper Fi
Old 12-23-2012, 06:00 PM
Anyone got any more ideas on the position reset problem? I've got this too and cant get around it. I've tried the wiper delay relay, but no joy. I think there may be another relay adjacent to the pump itself - could that be the root cause?
On mine, when the wipers stop in the wrong position I've found that the wipers wont run in continuous mode until you pull the lever to run the washers again (with the lever still notched up to the continuous run position). However, when I do this the wipers will then reset back to the bottom position - takes the guess work out of it.
Old 12-23-2012, 09:53 PM
AFM #725
Gawernator's Avatar
Could the wiper switch itself be the issue?
Old 12-23-2012, 09:56 PM
