darnellsgarage
No spark. Thoughts?
Changed out radiator . No start after. This doesn't make sense. Checked for spark. None. Swapped out coil wire. Changed cap and rotor. What's to look at next?
don
Old 12-25-2012, 05:22 PM
Is the king lead / coil wire secure at both ends - do you know if there is there a spark from the inside of the distributor cap to the centre of the rotor?
Assuming it is cranking - if not, could it be as simple as a loose battery lead?
Old 12-26-2012, 06:37 AM
darnellsgarage
Yep, doubled down on the coil wire. Cranks well, no problems there. I am just thourghly confused as to what I could have possibly pulled off in just changing the radiator. Car ran fine before. All I pulled off is the airbox and the dist. cap.
don
Old 12-26-2012, 08:20 AM
AFM #725
Gawernator's Avatar
Did you connect the firing order right
Old 12-26-2012, 08:52 AM
Proprietoristicly Refined
John_AZ's Avatar
Check the rotor and set screw.
Did you unplug the AFM connection?
AFM air intake swinging "door" --is it stuck? Moves freely?
and finally, when you crank the engine, does the tach bounce 1/16th on an inch?
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 12-26-2012, 08:54 AM
