-   -   Setting Chain Timing on 944S (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/726358-setting-chain-timing-944s.html)
87_944_S 12-31-2012 01:16 PM
Hi, Guys.
I have a Porsche that broke a timing belt or possibly the timing chain, and bent all the valves. So I got a cylinder head and new shafts, already had the head serviced (valve grind, stem seals replaced, guides replaced, surfaced), and now ready to install the new head. I also replaced the pads on the chain tensioner, and got a new chain.
So now I don't know how to set the timing of the cams with the chain. Are there special marks on the cams that show me in what position that cams must be for me to install the chains?
Thanks.
968 GUY 01-01-2013 02:09 PM
Best to refer to the workshop manual.
I can't remember if clarks garage has a writeup.
kfray 01-01-2013 03:33 PM
16 Valve engine info:
http://texasblake.com/porsche/docs/Vol1A-Engine16v.pdf
87_944_S 01-06-2013 01:16 AM
Cool. That manual helps a lot. Also has a lot of other great information. Thanks guys.
mhariush 01-09-2013 08:47 PM
I did this on mine a while back, bought a car with bent valves. It's a bit of a pain to get it all lined up, but hang in there, follow the manual and you'll get it :) 4200 miles later and car running like a champ :)
