Setting Chain Timing on 944S
Hi, Guys.
I have a Porsche that broke a timing belt or possibly the timing chain, and bent all the valves. So I got a cylinder head and new shafts, already had the head serviced (valve grind, stem seals replaced, guides replaced, surfaced), and now ready to install the new head. I also replaced the pads on the chain tensioner, and got a new chain.
So now I don't know how to set the timing of the cams with the chain. Are there special marks on the cams that show me in what position that cams must be for me to install the chains?
Thanks.
Old 12-31-2012, 01:16 PM
968 GUY's Avatar
Best to refer to the workshop manual.
I can't remember if clarks garage has a writeup.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 01-01-2013, 02:09 PM
yarfk
kfray's Avatar
16 Valve engine info:
http://texasblake.com/porsche/docs/Vol1A-Engine16v.pdf
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 01-01-2013, 03:33 PM
Cool. That manual helps a lot. Also has a lot of other great information. Thanks guys.
Old 01-06-2013, 01:16 AM
mhariush's Avatar
I did this on mine a while back, bought a car with bent valves. It's a bit of a pain to get it all lined up, but hang in there, follow the manual and you'll get it 4200 miles later and car running like a champ
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 01-09-2013, 08:47 PM
