While we're on the subject of hubs and bearings...
After warping 3 sets of rotors my local shop tells me they found the problem. My front hubs are warped! That's why I keep warping the rotors. He say's Porsche issued a service bulletin back in '94 on this so I must not be the only one with this problem. Has anyone else experienced this? I found a set of used hubs for $100 each. New ones are $600 each. I don't want to get used ones if they may warp also. Help! If I spend much more $$ on this car I'll be sleeping in the back yard!
Thanks!
Steveo
'90 944 S2 Cabrio Black/Black
Old 07-29-2002, 08:11 PM
AFJuvat's Avatar
I've heard of it - it was one of those "replace as needed" parts. Some had the problem, others didn't.
The original part for your model year was replaced.
The new part number is:
944 331 067 01
if the used ones have that part number, you should be good to go.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-29-2002, 08:39 PM
SoCal Driver's Avatar
Why can't the wheel studs be removed, the hub normalized (heat treated) and the mounting face resurfaced/turned?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-30-2002, 09:24 AM
Thanks!...but...
Thanks AFJuvat! Could you check that part number? They tell me 944 331 067 01 is a part number for rear hubs and I need fronts. The hubs they have are 951-341-065-06 but they may have others also.
Old 07-30-2002, 02:09 PM
I am reasonably sure that the bulletin only refered to 993 models.
However it would be applicable to any car, not only Porsches.
The usual problem is the wheel nuts being tightened with an air wrench. Porsche forbid this (and so no-one uses them..) You can rotate the disc on the hub until a more favorable run-out is measured. If that doesn't work it's new hub time.
I can't really see any reason not to machine the hub face, but you would have to ensure that the caliper was centralised.
Porsche, like Mercedes and BMW now use wheel bolts, part of the reasoning was to prevent the hub "pulling" when the studs are pressed in.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-30-2002, 02:25 PM
