-   -   Move it around a bit (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/72718-move-around-bit.html)
Eturbo924 06-27-2002 05:13 AM
You need to gently move it back and forth and allow it to come down a bit. It is the only way to get enough movement off the shaft. My 924 was very reluctant to shed its transmission. Slightly lowering it and moving it around a bit was the only way to get it off. Be carful not to shake the car off the jack stands.... always have more stands as back ups if you are under the car. More is better.....
Good luck
Eric
Eturbo924 06-27-2002 05:17 AM
oops this was supposted to be replay to LiL Help the 924S transmission issue.
Bob's944 06-27-2002 07:13 AM
ummmmm.... I'm glad you clarified that... was sounding very sexual there Eric. :eek:
Eturbo924 06-27-2002 07:24 AM
Bahahahaha Yeah I knew some one was going to have as sick a mind as mine. Yes this is about getting the transmission off... not your lover.
Eric
http://www.pelicanparts.com/support/...s/pftroest.gif
pearldrum 06-27-2002 07:52 AM
wow, that was really funny when thought about in a different way...
