Tach
My tach sometimes works and sometime does not. Any ideas. Also, does anybody have a printable complete vacuum diagram for a 1987 944 NA.
1978 924 The Grey Ghost - 18,000 miles and counting 1987 944 Black Betty - Bringing back from years of abuse |
I remember a thread not too long ago about a flaky tach most likely being caused by a bad solder joint(s). These can be repaired if you are careful.
Fixed; Intermittent tach |
Yep, and the contacts on the printed circuit where the bolts go though also get corroded and make bad connections. I pulled my cluster, took the tach out, cleaned all the contacts, then hit all the solder joints on the back of the tach with a soldering iron just long enough so they'd flow. Put it back together and haven't had a problem since.
That sounds easy enough, I may be able to to do it. Of course I will have to wait until the weather warms up a bit. Next week the high daily temps will be in the 20s. I hate winter in Cincinnati.
How about a vacuum diagram. Thanks
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Does that diagram show the vacuum lines?
Follow the dots-------------------
Where is the heater valve in this diagram.
Does the heater valve have a vacuum line attached to it.
What do you mean by heater valve ,are you talking abour what we call the (cold start valve)?
heater control valve
It's "J" in the picture.
Edit: Hmm. Nope that's not it.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ Last edited by Volhv; 01-17-2013 at 07:33 PM.. Reason: I was wrong. |
The late 944 heater control valve is vacuum operated, the early is cable. I don't have a diagram to help you though!
AFM #725
Not sure how this went from Tach to heater control valve but pelican says this is the HCV 92857457303
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
The valve circled in Ernie's picture is in fact an emissions control valve, and its hoses lead to the charcoal canister, and fuel tank. "J" in the diagram.
The heater control valve is the thing leaking in Gawernator's engine bay. Located between the head, and heater core.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
AFM #725
Just waiting on the mail now
The heater control valve is the thing leaking in Gawernator's engine bay. Located between the head, and heater core.[/QUOTE]_________+1 on the location & the early car like mention was cable operated.On late car it is vacum operated and is in the same location or almost. Early car HCV HCV location on early car
