Running without airco-compressor?
Hi,
I have NO idea how much power the airco/compressor uses from the engine when it's turned off, but how about just taking a smaller belt to drive only the alternator? Or is this useless, as the A/C will not require any power at all when not running?
By the way, i know there is a A/C deletion kit for race purposes. I'm pretty sure it will make it a couple of pounds lighter (what, 80 pounds, all-in?).
Old 06-30-2002, 10:46 AM
951carter's Avatar
You can delete the Ac w/out the kit. You have to use an adjuster from the power steering to adjust the alternator for belt tensioning, with a smaller belt of course. I used this to limp home before when an AC compressor mount tab broke.
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 06-30-2002, 11:09 AM
