GreenWater's Avatar
Reverse light fuse keeps blowing
The reverse light wasn't working so I checked the fuse and it was blown, so I replaced that, but it keeps blowing. I have also replaced the reverse light switch on the tranny. Fuse still blows. It looks like power goes from the fuse to the switch on the tranny and then to the light bulbs. Everything appears to be fine visually, and I am confused. I don't think a loose ground would cause the fuse to blow. A positive wire being grounded would cause the fuse to blow, right? That would mean that I have a cut wire grounding itself to the car SOMEWHERE? Has anyone else had this problem.
By the way, all the other tail lights still work fine.
I think the next thing that I need to try would be removing the wire that goes to the switch on the tranny and seeing if the fuse still blows, which I don't think it will. That would mean that the problem lies after the switch right?
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 02-05-2013, 07:23 PM
Patrick
pfarah's Avatar
Does it blow as soon as you replace it or does the fuse blow once you shift into reverse and the reverse lights go on? You seem to have a short. Look in your tail light assemblies and wiring back there including the ground bolt. Inspect for corrosion, open wires, breaks, or anything funky looking.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 02-05-2013, 08:22 PM
GreenWater's Avatar
It doesn't blow when I put the fuse in, it blows when I shift into reverse. That should mean that the short is after the switch on the transmission. I guess I should be able to figure it out with a multimeter. I just thought there might be something that other people knew about. Thanks
84 944
Old 02-05-2013, 08:39 PM
Patrick
pfarah's Avatar
You could try and remove both reverse light bulbs then shift into reverse. The circuit should remain open then test voltage. There may be a pinched wire or an area with missing insulation that's grounding out. Definitely look at the rear hatch area for wire discrepancies then look at the fuse panel.
Old 02-06-2013, 05:16 PM
Gday mate. Just seeing how you went fixing it? I have the same problem.
Old 10-22-2018, 07:16 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Good News:
You can incorporate 2 Rectifier diodes (1n4001) in series with the reverse break light circuit. This will only allow current to flow in one direction. Install one before Light and second after to ground, This will work....You definitely have reverse current and a floating ground somewhere in this circuit. Buy from Amazon.com. Easy to install
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 10-22-2018, 08:30 PM
GreenWater's Avatar
That sounds like one way to fix the problem. Ideally you would want to figure out why there is current going to the light and solve that issue. Maybe a ground or broken wires (which I hate trying to find).
That was an old thread. I fixed my car by selling it. lol. But I told the new owner all the problems before he bought it.
84 944
Old 10-23-2018, 09:29 AM
