Andrew Gawers' Dad
CHICKS's Avatar
Headlights wont stay up!?
I noticed recently on a night drive that my headlights start to slowly drop down until I can only see a few feet in front of me. If I shut the lights off, and turn back on, they come up to the correct height. This is a ongoing cycle, and from fully open, to where I cant see takes about 15min of driving. Any ideas? Thanks!
Old 02-07-2013, 07:37 PM
Banned
relay leaking current?
Old 02-07-2013, 07:38 PM
Andrew Gawers' Dad
CHICKS's Avatar
So the motor uses power to keep the headlights in the up position? It's not some kind of mechanical lock? I'll check the relay, I might even have a spare to test. Thanks!
Old 02-07-2013, 07:42 PM
FrenchToast's Avatar
The motor could not possibly use power to keep them up.
Check the nut on the end of the output shaft on the headlight motor. That keeps the linkage on the spline. Or perhaps the splines are worn.
However, this wouldn't make much sense as the motor is not self-calibrating. If it drooped, and was turned off and then on, it should come up past the drooped position. Unless there's an electrical issue and a mechanical issue.
Oh I don't know.
Take care!
Old 02-07-2013, 07:57 PM
Banned
no but the motor drives them down, and the relay might not be fully switching, or holding position.
Old 02-07-2013, 08:00 PM
Andrew Gawers' Dad
CHICKS's Avatar
French, um, thanks? Ahahahaha.
Cocker, i'll give a new relay a try in the morning, thanks again.
Old 02-07-2013, 08:02 PM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Viagra?
(who could resist)
can't wait to see if the new relay resolves.
GL
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 02-08-2013, 07:54 AM
The link below gives a great rundown on the headlights and motor, lots of pictures.
944 Foot To The Floor: How To Troubleshoot Porsche 944 Headlight Problem
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-08-2013, 11:10 AM
Andrew Gawers' Dad
CHICKS's Avatar
Cheers,
Larry
Thanks for that link, I saw it before, and actually forgot about it.
I pulled the relay and cleaned the contacts real good. I jiggled it around, then put it back it. Went on a drive, and it seems to be working now. I went ahead and ordered a new relay to be sure. Maybe there was some corrosion inside? (I am missing the boot/cover). The contacts were a bit dull, but not to bad. If it happens again the next step will be to tear the motor apart, or just put on a known working one. Thanks everyone!
Old 02-08-2013, 02:29 PM
The rubber boot does not cost that much and well worth getting.You can order it right here on PP.
Protection Cap Upper, pt # 477-941-387 Protection Cap for Relay, pt # 477-971-923
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?SUPERCAT_FLAG=&make=&please_wait=N&forumid=&threadid=&command=DWsearch&description=477.941.387&x=8&y=10#
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=see_more&please_wait=N&db_record_number=61837&PART_SEARCH=Y&SUPERCAT_FLAG=&make=&description=477%20971%20923
Cheers,
Larry
Old 02-08-2013, 07:46 PM
It was late. And what can I say?, I generally have no idea what I'm talking about anyway.
Did you check the analog compression reactor? After that I would check the genuine optic re-insulation motronic embellisher. Sometimes the hexaradiant spiral tangent calculators go bad.
Or maybe you live in a strange place where there is extra gravity?
Take care!
Old 02-08-2013, 09:46 PM
French.......you are too funny!!!!!!!!!
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 02-08-2013, 09:51 PM
Andrew Gawers' Dad
CHICKS's Avatar
Grandad#3, thanks again for the part numbers, i'll get em ordered monday.
Mr. Toast, the strange place I live does has a tid bit more gravity, so totally different problems.
Old 02-09-2013, 01:38 AM
flash968's Avatar
get a younger girl with perkier headlights? did i say that out loud?
Old 02-09-2013, 06:32 AM
ernie9944's Avatar
YES you did you dirty old fart.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-09-2013, 09:14 AM
flash968's Avatar
lol - i've worked long and hard to become the dirty old man i am today.
and those are just obscene.
Old 02-09-2013, 09:21 AM
ernie9944's Avatar
Well lol if you can't take it just close your eyes & go back to bed.
Old 02-09-2013, 09:25 AM
flash968's Avatar
lol - noooooo! i'll have nightmares about being smothered.
i feel sorry for her. the back pain must be a killer.
Old 02-09-2013, 09:56 AM
AFM #725
Gawernator's Avatar
What the Fuch Ernie
Old 02-09-2013, 06:02 PM
