-   -   broke my O2 sensor wiring (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/733019-broke-my-o2-sensor-wiring.html)
thekidd 02-08-2013 12:21 AM
I am trying to figure out my no start problem, and while I was trying to take my speed/ reference sensors out along with the bracket i broke my O2 wiring. I broke it on the harness side, not the side sensor side where Id just get a replacement sensore. Took the sensor out last when I did my clutch job a few months ago, and the plastic connections were very brittle on both ends (yellow). The connections actually did break and crumble some. Didn't tend to the matter because I was focused on getting the sensor bracket out at the time, and didn't pay attention to the O2 wiring after I noticed that I broke it. Forget how it was connected, I think it was soldered, or can I just splice the wiring someway. A car will start w/o the O2 sensor connected correct? I do need a new O2 sensor, but cant get it out.
Gawernator 02-08-2013 12:33 AM
No worries dude, the car is still drivable.
thekidd 02-08-2013 12:40 AM
thanks. that's what I thought, just wanted to double check it didn't need to be connected to start and drive.
Gawernator 02-08-2013 01:20 AM
Engine runs in open loop
Grandad#3 02-08-2013 11:13 AM
Open Loop means the engine will run richer, less MPG.
Cheers,
Larry
uvachief 02-09-2013 08:38 AM
O2 Sensor
I've got an extra new Bosch universal sensor if you want it. I am too chicken poop to splice it. There is bound to be a thread on how to do it.
Grandad#3 02-09-2013 05:24 PM
Hi Kidd, On the Universal o2 wires never solder the wires together, slide on shrink wrap prior to crimping the Butt Joint connector. Heat the Shrink Wrap so you will have an Air Tight Connection. Another joint connection is shown in the link below.
http://www.google.com/url?sa=t&rct=j&q=bosch%20o2%20sensor&source=web&cd =3&cad=rja&sqi=2&ved=0CEoQtwIwAg&url=http%3A%2F%2F www.youtube.com%2Fwatch%3Fv%3Dex1Hki6-NHw&ei=OO8WUdSLFInQ2AXqxoHoAw&usg=AFQjCNGX4mdbveoD jDkf54o-lUTgI0uO3A
Cheers,
Larry
Gawernator 02-09-2013 05:41 PM
The new ones come with Posilock come connectors
