thekidd's Avatar
Send a message via AIM to thekidd
broke my O2 sensor wiring
I am trying to figure out my no start problem, and while I was trying to take my speed/ reference sensors out along with the bracket i broke my O2 wiring. I broke it on the harness side, not the side sensor side where Id just get a replacement sensore. Took the sensor out last when I did my clutch job a few months ago, and the plastic connections were very brittle on both ends (yellow). The connections actually did break and crumble some. Didn't tend to the matter because I was focused on getting the sensor bracket out at the time, and didn't pay attention to the O2 wiring after I noticed that I broke it. Forget how it was connected, I think it was soldered, or can I just splice the wiring someway. A car will start w/o the O2 sensor connected correct? I do need a new O2 sensor, but cant get it out.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 02-08-2013, 12:21 AM
AFM #725
Gawernator's Avatar
No worries dude, the car is still drivable.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-08-2013, 12:33 AM
thekidd's Avatar
thanks. that's what I thought, just wanted to double check it didn't need to be connected to start and drive.
Old 02-08-2013, 12:40 AM
AFM #725
Gawernator's Avatar
Engine runs in open loop
Old 02-08-2013, 01:20 AM
Open Loop means the engine will run richer, less MPG.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-08-2013, 11:13 AM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
O2 Sensor
I've got an extra new Bosch universal sensor if you want it. I am too chicken poop to splice it. There is bound to be a thread on how to do it.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 02-09-2013, 08:38 AM
Hi Kidd, On the Universal o2 wires never solder the wires together, slide on shrink wrap prior to crimping the Butt Joint connector. Heat the Shrink Wrap so you will have an Air Tight Connection. Another joint connection is shown in the link below.
http://www.google.com/url?sa=t&rct=j&q=bosch%20o2%20sensor&source=web&cd=3&cad=rja&sqi=2&ved=0CEoQtwIwAg&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dex1 Hki6-NHw&ei=OO8WUdSLFInQ2AXqxoHoAw&usg=AFQjCNGX4mdbveoDjDkf54o-lUTgI0uO3A
Cheers,
Larry
Old 02-09-2013, 05:24 PM
AFM #725
Gawernator's Avatar
The new ones come with Posilock come connectors
Old 02-09-2013, 05:41 PM
