Talking porsche 944
I need help with my 944 will not crank, replace ignition swith, starter nothing, battery is new can anyone help : 1983, 5 speeds engine turn by hot wire the starter
Old 02-17-2013, 05:43 PM
alan6272's Avatar
more info please, year,auto? stick? no crank means engine will not turn?
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 02-17-2013, 05:49 PM
AFM #725
Gawernator's Avatar
If you don't get a tach bounce your reference sensor is probably suspect.
Old 02-17-2013, 06:02 PM
ernie9944's Avatar
+1 on reference sensor.Suggest you use this garage for your troubleshooting ,it will be your best friend from now on.Clark's Garage Home Page (enter Garage Shop Manual) for your particular issue scroll down to (troubleshooting TS -01 (includes oil pressure problems).GL
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-17-2013, 06:52 PM
ernie9944's Avatar
I need help with my 944 will not crank, replace ignition swith, starter nothing, battery is new can anyone help : (1983, 5 speeds) engine turn by hot wire the starter
Originally Posted by alan6272 View Post
more info please,( year,auto? stick?) no crank means engine will not turn?
___83-5speeds__________________Like he said.
Old 02-17-2013, 06:59 PM
thekidd's Avatar
Send a message via AIM to thekidd
Try cleaning the grounds (battery, and the ground connected to the firewall to the engine, and also the small ground on the rear of the engine by the speed and reference sensors) Make sure your starter wire is clean at the battery terminal, and after you do these (all free), and you still dont get it to crank or tach bounce, then it may be the speed and reference sensors. How new is the DME relais?
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 02-18-2013, 01:03 AM
alan6272's Avatar
edited it ernie, was not on the first post
catalina22 sold
baja ski boat sold
my toys
Old 02-18-2013, 04:33 AM
