-   -   Suspension mod primer thread? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/736972-suspension-mod-primer-thread.html)
Rupert944 03-02-2013 10:40 PM
Apologies if I missed an obvious one, and it seems like there has got to be something, but I'm starting to think about suspension modification on my '86. I know what I want the end result to be (good for long distance but really good for twisty roads), but I need more info on what I need to do to get there. Stock is too roly poly and it seems like it could be tighter in general.
Where's the thread I need? Or is this now that thread?:D
Mike_944 03-02-2013 11:05 PM
I had the same question for my 85.5. A lot of good recommendations here!
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/734969-best-suspension-800-a.html
Gawernator 03-02-2013 11:24 PM
There's a lot of choices out there.. if you're not looking to spend a lot but want to refresh your worn and tired struts and shocks Bilstein is a good choice for performance that's not the price of Koni's. In fact I have a set of rear Bilstein for a 944 (If you want PM me). There's also of course Koni, just OEM Sach/Boge, coilover setups. I personally have a 26.8 hollow front sway bar, 16 mm rear, a castor block brace, strut tower brace, and am putting on Koni Ground Control Coilovers ($$)
Also, not sure of your car's condition but with just all new rubber OEM bushings and new OEM dampers you'd probably notice a much nicer ride. Lowering springs combined with Bilstein struts and shocks would be good bang for your buck.
Rupert944 03-03-2013 06:15 PM
Cool, a few good links in that thread. Particularly this one: Suspension Information and Upgrades. Shoulda thought to look there first!
It's looking like the best option for the rear suspension is going to be coil-overs, either as a helper for the torsion bars or to replace them. On thing is I don't want to get too stiff, because I do drive the car on long road trips. I don't really know what spring rates should be going where...
Also, I want to do the bushings, just replace them with OEM rubber. It's a bit confusing trying to figure out what I need for the suspension and sway bar bushings. Is there a kit or a guide or something?
Gawernator 03-03-2013 06:32 PM
Look through the Pelican Catalog, and I am running 250# front spring rate 150# rear with 23.5mm torsion bar.. you'll need helper springs in the rear though (and a coupler on each side).
Rupert944 03-03-2013 06:55 PM
Pelican catalog is why I'm confused!
So if I have a 126 lb torsion bar, and I want a 150 lb total spring rate, do I then find a helper spring that's 24 lbs?
Gawernator 03-03-2013 07:03 PM
Helper springs don't add spring rate, they keep tension on the spring so it doesn't fall loose off the perch. Only needed if you keep a torsion bar
Rupert944 03-03-2013 07:05 PM
Eh, then what am I talking about? When you do add a spring (i.e. a full coil-over) to the rear and keep the torsion bars. I know it's a thing...
Rupert944 03-03-2013 07:18 PM
And isn't a 250 lb/150 lb spring setup really understeery? The impression I have from the Clark's Garage info is you want equal-ish rates F to R on these cars...
Gawernator 03-03-2013 08:13 PM
150+126= 276 actual spring rate rear
Rupert944 03-07-2013 08:55 PM
For spring rates, I'm thinking as near to 200-210 lbs as they sell all around, and for anti-roll bars, 30 mm front and 19 mm rear. Still not sure on shocks, or how I want to do the rear suspension (new torsion bars, replace torsion bars with coil-overs, or add coil-overs to the torsion bar setup). Also having second thoughts about the bushings-- seems like a pain in the ass.
Paragon sells kits for $2k that have Koni Yellows (or at least yellow Konis) with torsion bars and anti-roll bars, but the spring rates seem maybe a little high. It's not a race car, ya know?
Thoughts on any of that?
Gawernator 03-08-2013 12:11 AM
If you think replacing bushings are too much, torsion bar will murder you....
Dude brand new rubber bushings will make a big difference, you really should, it's not expensive either. Makes no sense AT ALL to put thousands into coilovers or dampers etc and have crappy cracked ruined rubber bushings that are all slop.
I still have those Bilstein shocks for cheap
petrolhead611 03-08-2013 03:34 AM
The standard suspension in good condition is good enough for twisty European roads, so for US highways it should be more than adequate. Just change all the bushes, check and replace as necessary all steering joints to start with, and brace the front swaybar inner mountings.
Rupert944 03-08-2013 07:11 PM
Heh, I'm a lazy bastard; can't be denied! That's why the torsion + coil setup appeals to me. I'm not sure the condition of my bushings, so I think that's my first step. My guess is that they're in good shape for being 26 years old.
I know I can do the work without issue right up until the torsion bar stuff. Pretty sure I would murder a kitten in a fit of rage doing that...
I'm still a few months away from doing this, but I might hit you up for those shocks if you still have them then.
Rupert944 03-08-2013 07:12 PM
Well now, if I agreed with that, I wouldn't have made a thread!
Gawernator 03-08-2013 07:14 PM
Yes, I do.. still shiny looking. I like how they say Nordschleife tested on the side :)
Rupert944 03-08-2013 08:09 PM
How much? And which shocks?
333pg333 03-08-2013 09:39 PM
Are you talking with or without a T-bar? Due to the motion ratio on these cars (not the spring rate), you need to have higher rated springs on the rear than the front. So leaving T-bars out of the equation for the moment. You would want at least 10% more in the rear but really you can run up to 20% pretty easily. A friend of mine took his modified turbo to a suspension guru who has him on something like 850lb front and 1200lb rear on Moton Clubsports. I've got 900/1100 on the same Motons. Of course this is more extreme rates than most would run but the ratio should be the same.
Here is an email I had from Karl Poeltl or the owner of Racers Edge. This was from some years ago when I was trying to figure out what I had on some KW suspension. (Very good if you can afford it.) This will help understand what motion ratio is.
"The info on Paragons site is stuff they got from me a few years ago. In any
case, the 47% is a number that I have calculated By taking measurements. I
am now pulling out one of Porsches own Motorsport sheets that shows all the
rates of their Turbo and "Cup" cars back when they ran competitively.
Porsche lists the 25.5 mm bar as 31 N/mm which is 177 lbs/in. They also then
give the variable rate coilover helper spring rates at 34-65 N/mm which is
194 lb/in - 371 lb/in. They then give the total Rate at the wheel(T-bar plus
coilover) as 45.4 - 58.5. Back out the rate at the wheel due to torsion bar
which they list as 31 and you have 14.4 - 27.5 at the wheel due to the coil
over. So take your pick, 14.4 / 34 is approx 42% or 27.5/65 is 42%.
Bob is right about them being inboard but his numbers are off. Actually they
are correct I think in that the motion ratio is about 65%. But when
calculating wheel rates from spring rates it is the motion ratio squared
that is uses. So 0.65 ^2 is , guess what,... 42.25% which is the number that
Porsches own sheet claims as I outlined above. So your torsion bar is 177 at
the wheel, and your helper spring rate is a 285 which is 119.7 lb/in at the
wheel. So working backwards 177 plus 119.7 is 296.7 pounds per inch at the
wheel. Divide this by .42 and that is you equivalent coilover, or 706 lb/in
coilover (initially I had 661 lb/in which is attributable to my measurement
error - I had 47% and Porsche lists it at 42%).
So it may be a bit stiffer in the rear than I might run but with the ability
to tune sway bars etc... you should be Fine. Your setup is actually much
stiffer in the front than the Porsche cup setup which ran progressive front
springs (200 - 371 lb/in) with the rear setup I described above which is not
that far from what you have( yours is 296 at the wheel and theirs was 259 -
334 lbs/in at the wheel).
Hope this make sense, but believe me, what is above is 100% correct. I can
fax you the Porsche motorsport sheet if you think it will help."
Gawernator 03-08-2013 11:26 PM
I'd love if you'd e-mail me that, ha
Rupert944 03-09-2013 12:35 AM
I'm not tracking my car, so I frankly don't care what the cup cars from back in the day were doing.
Ugh, Porsche snobbery. ;)
Explain why higher rates in the rear won't make the car understeery, and try to make the numbers you use meaningful to those of us who aren't already experts.
edit: I meant oversteery, derp.
Gawernator 03-09-2013 12:50 AM
Higher Rear spring rates actually contribute towards oversteer, not understeer.
Rupert, you have a PM ;)
http://www.drivingfast.net/car-control/oversteer.htm#.UTr3mqX_Q20
Rupert944 03-09-2013 12:57 AM
Oops, yes, reversed that in my mind. Same link suggests equal front-rear spring rates.
Gawernator 03-09-2013 12:59 AM
Yes, a neutral setup I think is pretty preferable for a daily driver. I'm at #250 front and about #267 rear effective
Rupert944 03-09-2013 04:54 PM
Alright, what about this setup:
Ground Control - 944/924/968 - C/O Strut Assemblies (pair)
Ground Control - 944/968 (Rear) Coilover Assembly (Pair)
Porsche 924S, 944 and 968 Front 30mm Sway Bar by Lindsey Racing.
Porsche 924, 944, 968 MO30 Lindsey Racing REAR SWAY BAR 19mm 5 WAY - M030 club sport.
Spring rates for the front of 210 lbs, and spring rates for the rear of 90 lbs (keep stock torsion bars @23.5 mm for total of 216 lbs). All that plus various hardware would be around $2k. Bushings look like another couple hundred.
I think I can do the work on all this, unless I have to **** around with the torsion bars. It looks like the coil overs are all height adjustable (?), so it seems like the height would be easy to get right that way.
Is there a cheaper way to get this result (or nearly this result) without getting into torsion bar replacement?
Gawernator 03-09-2013 07:14 PM
I have the first two Ground Control products on my car, except I kept the stock strut body. Not sure if you can get a front spring in 210#. Unless you re-index or remove the torsion bar the lowest drop you can get in the rear is about 3/4" with the eccentric adjustment, and you will need helper springs and couplers for the rear coilovers. I spent about $1,400 or so. Not including my sway bars and bushings, did those a while ago.
Rupert944 03-10-2013 03:48 PM
Well, worst case, I pay to have the torsion bars re-indexed.
How do the helper springs and couplers help? I.e., where do the springs go, and what are these couplers?
Did you change out the inserts yourself, or send them off? It looks like the inserts are quite a bit cheaper.
Gawernator 03-10-2013 03:57 PM
My 86 was the last year with non-sealed struts so I changed out inserts, I've done it twice, kinda a PITA but not too bad. Helper springs keep the main spring from falling off its perch and the coupler connects main spring to helper spring, because the weight of the car will rest on the torsion bar and not the coilover unless the torsion bar is deleted.
9FF 03-10-2013 04:55 PM
..I think I can do the work on all this, unless I have to **** around with the torsion bars. It looks like the coil overs are all height adjustable (?), so it seems like the height would be easy to get right that way.<br>
<br>
Reading through this post and I don't want to come across as rude, but it seems you need to get a better understanding of what you are planning and reassess if you are up to doing this task yourself. If you start yiurself and end up paying someone to do this it will be very expensive. To do it properly:
1. If you upgrade your front springs you WILL need to reindex your torsion bars. This requires you remove and refit your complete rear suspension subassembly at least once, normally twice and in some case three times.
2. Fitting coilovers at the rear with torsion bars fitted will also require you to reindex them as (1).
3. With torsion bars fitted the coilovers at the rear will NOT adjust ride height, only a torsion bar reindex will do that.
4. Putting coilovers at the rear really just add to the spring rate of the torsion bars.
5. The helpers and spacers Gaw is referring to fit on the coilovers and stop the springs from dislodging from their mounts on a bump, they do not add to the spring rate but without them your coilovers are useless.
6. If you remove the torsion bars completely and fit coilovers, only then can you adjust your ride height at the rear using the coilovers. You will have to up the spring rate substantially with the torsion bars removed and probably strengthen the bottom mount with an adapter depending on which coilover you use.
If you are uncomfortable with any of that then I'd advise you to follow the previous answer by another poster:
Rupert944 03-10-2013 05:56 PM
Ever notice that when someone says, "no offense, but," they are invariably about to be offensive? Maybe next time, answer the questions I have without being a prick? Because those are decent answers.
So, what, were you born with All Porsche Knowledge already installed?
Rupert944 03-10-2013 06:01 PM
Alright, so the helper springs go on the unit with the springs? That makes sense.
I'll look into the process for changing the strut inserts to see what I want to do there.
9FF 03-10-2013 06:05 PM
Ever notice that when someone says, "no offense, but," they are invariably about to be offensive? Maybe next time, answer the questions I have without being a prick? Because those are decent answers.<br>
<br>
Sorry I offended you, you obviously don't have a brain that can differentiate between advise and criticism.
Having owned one of these from new and had a total of 8 of them, track them regularly and basically stripped them top to bottom, I thought I'd help you out...guess it's not needed...bye and GL
Rupert944 03-10-2013 06:34 PM
Like I said, the advice part is appreciated, just tone down the superior attitude.
Gawernator 03-10-2013 10:53 PM
Strut Removal and Replacement
Rupert944 03-11-2013 06:16 PM
Thanks! That's not bad, excepting I don't have an impact gun. I might look into that, since this isn't the first time I've wanted one, but it would be simpler if I just took it to a shop to have the replacement done. Food for thought!
ernie9944 03-11-2013 08:57 PM
Originally Posted by Rupert944 (Post 7322988)
Thanks! That's not bad, excepting I don't have an impact gun. I might look into that, since this isn't the first time I've wanted one, but it would be simpler if I just took it to a shop to have the replacement done. ___ Food for thought!
___+1 You can save yourself some money by just removing the complete unit (easy to DIY) & have the replacement done at a shop with the proper tools.It will save you lot of hassle be safer & won't cost a fortune.:D
Gawernator 03-11-2013 10:18 PM
Well you should have a non sealed strut. You'll need an impact gun sooner or later... And why wouldn't you want one anyways for wheels etc. spring compressors are $20-$30 on Amazon.
Rupert944 03-12-2013 01:13 AM
Impact gun means the whole compressed air apparatus, and then I would end up buying a bunch of other air tools, and the whole thing starts to get expensive.
You're right, though, sooner or later...
Gawernator 03-12-2013 01:33 AM
I have an electric one. However you'll want an air compressor lol. Personally I'm the type to either go all in or not at all. Same philosophy with my 944, however not necessarily healthy at my age haha. "Go big or go home"
Rupert944 01-13-2014 12:08 AM
*bump*
Finally got around to doing something here! I would have done this over the summer, but an Alfa 164S followed me home in June, and it took a little while for my bank account to recover...
I found a local guy who knows these cars and how to modify them, and his advice was to go with Bilsteins and the stock springs and t-bars, and then go from there. I had him install the shocks/strut inserts, as one of my ball joints was bad, and I didn't want to deal with replacing the control arm, so while he was in there...
I'm taking it back to get the t-bars re-indexed this week (back end has been sagging for a while). So far, though, I'm liking it a lot. It's not too stiff, and the body roll is reduced. I think I might get bigger sway bars (by a few mm), but I don't want to increase the spring rate at this point.
Just wanted to update this thread for posterity!
petrolhead611 01-14-2014 03:26 AM
Hopefully the car that followed you home was the Rudeness Patrol. You were unpleasant to me and another contributor on this thread-not the way to encourage people to help you.
