-   -   hood struts. Why did I wait so f#&@%$* long? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/737816-hood-struts-why-did-i-wait-so-f-long.html)
ditch68 03-07-2013 03:59 PM
Rhetorical question, really.Flame awayI deserve it.
I guess I dont nee the tiny vice gtip and the piece of rolled cordura anymore. D'OH.
Jeff
J1NX3D 03-07-2013 04:30 PM
im fit that catagorey too. i did try a pair of used struts for cheap but they were no good. long term, I'm going to adapt 968 hinges and struts to my car. slightly different arrangement and looks like it should work fine.
ckelly78z 03-07-2013 04:54 PM
Yep, picked up the car in November, and by December, new struts in place for the hood and hatch. I actually threw the black painted stick away......I know, blasphomy.
Gawernator 03-07-2013 05:12 PM
You guys are hilarious. One of the first things I did to my 83 was new hood and hatch struts. When my 86's hood strut started getting weak on one side, I ordered two new OEM ones the next day. Lol. :eek:
kfanazini 03-07-2013 05:43 PM
I thought I read somewhere that the are hard to install?
J1NX3D 03-07-2013 06:35 PM
they are not!! less than a minute each side. probably longer to take them out of the box. the rear struts are equally easy.
ernie9944 03-07-2013 07:11 PM
The Weltmeister HD hood shock are one of the best out there with a lifetime warranty.During my twenty six years off 944 ownership I did replace the hood shocks at least three time to no avail,so I decided to buy the HD one, and after five years on the car they are still going strong.The rear hatch one I only had to replace once.http://forums.pelicanparts.com/uploa...1362715749.jpg:D
POPS 83 944 03-07-2013 08:37 PM
I'm actualy going to eliminate my and go with the 924 hood prop, seeing that I have an early 944 With the prop holder on the driver side inner fender and I'm putting a 931 hood with no place to put the shocks on (it is already being painted and didn't get a chance to weld on the mounts)
Chunkerz 03-07-2013 08:47 PM
If anyone reads this thread and decides to go out and change their hood struts, I have a very important tip for you: place a piece of cardboard or two (depending how thick it is) between the two rear corners of the hood and the windshield. If the hood slides back those sharp corners can crack/chip your windshield.
Gawernator 03-07-2013 11:08 PM
Nope, nothing is necessary besides this simple step. Put both of the hood shocks into the freezer. Go to bed. Next day just take off that clip and the pin and pop in the new shock on each side. Simple.
curtisr 03-08-2013 02:43 AM
Originally Posted by POPS 83 944 (Post 7315802)
I'm actually going to eliminate mine and go with the 924 hood prop
Ditto. When the struts die.
ditch68 03-08-2013 05:33 AM
Mi.e required no freezer, and no cardboard, but both sound like reasonable methods.
Jeff
FLYGEEZER 03-08-2013 05:48 AM
No need to fear new hood struts.... the hatch is another issue. New struts on an old hatch will end up causing seperation of the glass from the frame. Don't do it ! My hatch hasn't been opened in years but if I do.... then a small pair of vice grips to hold it open.
ditch68 03-08-2013 07:00 AM
hilariois in that your first job when you got the car was hood struts, or hilarios in that I had no time becaise my first job on that car was a COMPLETE TORQUE TUBE R&R, THEREBY HAVING BIGGER THINGS TO WORRY ABOUT.
Until now. :)
Jeff
Gawernator 03-08-2013 10:10 AM
It takes 30 seconds per side!
ditch68 03-08-2013 10:12 AM
This thread was really intended as a joke.
Now you are in on it, too. :p
Jeff
Gawernator 03-08-2013 10:14 AM
Don't feed the trolls
Jferr006 03-08-2013 10:18 AM
My hood struts are useable but, not perfect(who knows, they may have been replaced at some point in the last 30).. The hatch struts are dead but, the latch mechanism is the bigger problem, one side sticks and has to be manually fiddled with from the inside. A thousand little things, where does one start :)
ditch68 03-08-2013 10:18 AM
Gawernator 03-08-2013 10:20 AM
My hood struts are useable but, not perfect(who knows, they may have been replaced at some point in the last 30).. The hatch struts are dead but, the latch mechanism is the bigger problem, one side sticks and has to be manually fiddled with from the inside. A thousand little things, where does one start <img src="http://forums.pelicanparts.com/ultimate/smile.gif" border="0" alt="" title="Smilie" class="inlineimg">
Hood struts. No exceptions. Lol
