Autothority Chips question ...
I've got a couple of Autothority chips and wanted to ask if I can just stick them in the DME and KLR. Don't have any more info on these except that they are 24-pin chips and:
PO.951.1.200.DME
PO.951.1.200.KLR
From what i've heard about Autothority, contacting their support is probably futile as I did not buy these new. They came with the car when I bought it used. They were swapped out and "saved" by the shop that replaced the older DME/KLR to fix a no-start issue.
Old 03-14-2013, 01:23 PM
Do you know anything about your banjo bolt? Is it stock? If it is stock I would not run these without a 15 psi max banjo bolt or a manual boost controller set at 15. Also to be on the safe side without a wide band sensor I would run 93 octane gas to be on the safe side.
Old 03-14-2013, 01:37 PM
Thanks Zedsn. I believe that the banjo bolt is stock. Good call on the MBC too. Instead of these chips I will probably go for Rogue's A-Tune.
Old 03-14-2013, 05:24 PM
