Mudd's Avatar
Voltage Regulator
Do I have to remove the alternator to change the voltage regulator.
1978 924 The Grey Ghost - 18,000 miles and counting
1987 944 Black Betty - Bringing back from years of abuse
Old 03-19-2013, 03:24 PM
Nope.
Two flathead screws on the back of the alternator
You need to pull your air box off to make it easier.
Old 03-19-2013, 03:32 PM
Mudd's Avatar
So I just go in from the top, remove the old one after I remove the air box and install the new one. I don,t have to go under the car at all.
Old 03-19-2013, 04:24 PM
Not one bit. Its built into the alternator.
Pull it out. Make sure which way its in there.
I recently took mine out yesterday. Lol
Cleaned yhe contacts/etc
Old 03-19-2013, 05:46 PM
Proprietoristicly Refined
John_AZ's Avatar
If you are putting a new VR in a very old alternator, the slip ring will eat the new VR carbon contacts.
This is what an old alternator slip ring looks like.
This is a new Bosch slip ring:
If you think the alternator is OK you can take it apart and put it on a lathe or at least file as best you can to get rid of the ridges that will eat the new VR contacts.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-19-2013, 05:51 PM
Eh. If your alternator is putting out 13.5v your regulator should be fine
Old 03-19-2013, 05:54 PM
