Startup tips needed
Members,
My car has been in winter storage since Thanksgiving, does anyone have any tips for the first start of the season, or any links to past threads? Thanks in advance, Ken
86NA944 |
That Guy
Check oil, pull DME relay and coil wire. Crank till you see oil pressure. Start and drive.
Search 'youtube' for Arthur Fonzarelli attempting to jump a shark on his motorcycle. This should lend some useful insight.
Lol...good luck ! Correction on water skiis!!! Lmao
1988 944 turbo Last edited by rick13; 04-11-2013 at 07:26 AM.. |
Ok. That's what I was going to do, thanks for the reply.
86NA944 |
report back if yours starts, mine did not.
I had to spray in starting fluid, but learn from mistake, spray in starting fluid, then reconnect the hose to the MAF. took me hours to and only I drained half the gas tank did I realize it. |
