-   -   Engine Rebuild Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/741569-engine-rebuild-question.html)
BimPorDuc 03-28-2013 08:20 PM
I have a car with a seized engine. Rod bearings. I purchased an '87 engine but #4 intake leaks so I'm exchanging it. The engine the breaker has also has a leak but it's slight and at #2. :( It's an '88. My car is an '85 (early). Yes I know about the DME and required changes.
My question is whether I should accept the '88 engine, pull the head and have it checked / repaired or wait for another engine from the wrecking yard. The other option is to keep the '87 engine and have the head checked and repaired. The bad thing about that one is that there was coolant in the intake plenum for #4 when I got it. Big red flag. IMO I should go for the '88 as they are comparatively rare. There will be added cost in having the head "done".
If the head is bad, could the case be bad too? The '87 engine turns over and "feels" fine. The '88 would be an improvement as it has 158 bhp vs. the '87 with only 147. Is the head on the '88 special or is the compression increase solely achieved by changing the stroke? How'd Porsche get more compression in the '88?
I bought this car for $4,000 and nearly everything worked. The rod bearings let go after an autocross and it's going to turn into an $8,000 car before all this is settled. Bummer. But then I'll have a "known commodity" to use as a driver for a few years.
Chunkerz 03-28-2013 09:04 PM
Everything is the same except for the pistons. They raised the compression by shrinking the dish in the pistons, not changing the stroke. I'd go for the 88 engine just for the 9HP increase, no matter what it needed.
Gawernator 03-28-2013 09:11 PM
'88
BimPorDuc 03-29-2013 09:55 AM
Thanks for the votes. What kind of compression numbers do '86 - '88 NA engines generate?
John_AZ 03-29-2013 10:11 AM
Per Clark's Garage Home Page
944 Technical Information
J_AZ
