Engine Rebuild Question
I have a car with a seized engine. Rod bearings. I purchased an '87 engine but #4 intake leaks so I'm exchanging it. The engine the breaker has also has a leak but it's slight and at #2. It's an '88. My car is an '85 (early). Yes I know about the DME and required changes.
My question is whether I should accept the '88 engine, pull the head and have it checked / repaired or wait for another engine from the wrecking yard. The other option is to keep the '87 engine and have the head checked and repaired. The bad thing about that one is that there was coolant in the intake plenum for #4 when I got it. Big red flag. IMO I should go for the '88 as they are comparatively rare. There will be added cost in having the head "done".
If the head is bad, could the case be bad too? The '87 engine turns over and "feels" fine. The '88 would be an improvement as it has 158 bhp vs. the '87 with only 147. Is the head on the '88 special or is the compression increase solely achieved by changing the stroke? How'd Porsche get more compression in the '88?
I bought this car for $4,000 and nearly everything worked. The rod bearings let go after an autocross and it's going to turn into an $8,000 car before all this is settled. Bummer. But then I'll have a "known commodity" to use as a driver for a few years.
'73 911T (Since '83 - PCA since '84), '10 C2S, '85 944 (Gifted), '83 944 (Sold);
BMWs: '00 328i ZSP, '03 525i M-Sport, '01 325i (Totaled), '96 328i (Sold), '97 328i and '07 328i (Daughter's)
Old 03-28-2013, 08:20 PM
Chunkerz's Avatar
Everything is the same except for the pistons. They raised the compression by shrinking the dish in the pistons, not changing the stroke. I'd go for the 88 engine just for the 9HP increase, no matter what it needed.
Old 03-28-2013, 09:04 PM
AFM #725
Gawernator's Avatar
'88
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-28-2013, 09:11 PM
Thanks for the votes. What kind of compression numbers do '86 - '88 NA engines generate?
Old 03-29-2013, 09:55 AM
Proprietoristicly Refined
John_AZ's Avatar
Per Clark's Garage Home Page
944 Technical Information
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-29-2013, 10:11 AM
