-   -   Suspension Refresh(Questions) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/742667-suspension-refresh-questions.html)
billy mild 04-03-2013 02:21 PM
I am looking to finally after 2 year redo the front suspension on my car. Car is mostly driven on the street, may seen an autocross this year if I can get everything done to it.
So the questions are:
1. Where to get bushings for the front control arms?(Swaybar, control arms) Can I get M030 rubber bushings for my car? (Are refurbing the arms really $500?)
2. Will 200 lb springs work well with Koni Strut Inserts?
3. Are the VW Fox strut mounts okay for the 86 951?
4. List of components to be replaced/fixed: Strut inserts, new front springs, control arm bushings/ball joints. Is there anything else I am missing on the front suspension?
A separate project will be to swap out my steering rack as mine is just puking fluid.
Gawernator 04-03-2013 02:58 PM
Available here, of course! Porsche 924S/944/968 Suspension - Page 4
Sure you can look around though...
200 should work, I'm at 250 and it's quite a nice ride with the Koni 1038S inserts set to half firm (Koni race shocks rear)
Check for tie rod play? Just replaced mine, some inner play and one torn boot. Check your strut mount bearings for play or seizing etc
Swaybar bushings? Possible size upgrade? You could get these for cheap http://www.rennbay.com/porsche-944-front-sway-bar-braces-p-125.html
billy mild 04-04-2013 07:15 AM
I will be sticking with stock swaybars for now. In the future I may upgrade to the M030 swaybars.
Tie rod play should be 0 since I replaced the whole tie rods on both sides last year along with my front wheel bearings
Rasta Monsta 04-04-2013 08:25 AM
Headed for a common mistake. . .increasing the front spring rate and leaving the rears alone will make the car push. Turn in at AutoX could be particularly bad.
T-bars - much ado about nothing, not that big a deal.
billy mild 04-04-2013 09:32 AM
This is about the front suspension. Later I will think about redoing the torsion bars/carrier.
Rasta Monsta 04-04-2013 09:45 AM
I must have misunderstood. Thought you were wanting to AX the car. Mods you are contemplating will FUBAR the handling.
Gawernator 04-04-2013 11:08 AM
Another reason I would recommend 220/250 etc springs... And in the rear either larger torsion bars or replace with coilover spring or both
guru944 04-04-2013 11:53 AM
Billy M;
Consider Polyurethane sway bar bushings and endlinks for both front and rear. This will help minimize body roll, especially around at +15mph cornering. In expensive upgrade(s) Energy Suspension, Prothane and Ricochet make sutable upgrades. Verify (measure with Vernier Caliper) what MM bars you have before you order. Your local Autozone or Lindsey Racing are good sources...
Keep us posted, Later...
guru944 04-04-2013 12:29 PM
For all;
Great site for suspension upgrades & These guys are serious....
ELEPHANT RACING Tech Topic, Polyurethane Bushings and Friction
Later
Gawernator 04-04-2013 03:31 PM
Autozone has sway bars for a 944? ...???
guru944 04-04-2013 03:54 PM
Gawernator:
You got me! Ha. Ha.! Let me clarify, Autozone for the bushings Energy suspension Polyurethane Bushings (End links and inner bracket bushings for front & Rear).
Paid ~ $34.00 for a pair of Rear greasable Poly's for my 944 last year... Imagine that..
Later...
billy mild 04-04-2013 05:12 PM
Originally Posted by guru944 (Post 7369153)
Gawernator:
Later...
Do you have part numbers for these bushings? Sounds cheaper than the other poly bushings. What about the front of the aluminum control arms any idea on this bushing?
Gawernator 04-04-2013 05:16 PM
Yes, I'm curious too. Could switch to those when my rubber dies, maybe
guru944 04-04-2013 07:42 PM
Enjoy all...
Prothane Link:
Universal Product Guide Page 1 | Prothane
Energy Suspension Link:
energysuspension.com | Sway Bar & End Link Bushings
Porsche Shop Link:
Porsche 944 Suspension Upgrades | Wishbone Bushes & Shock Absorber Dampers UK
Lindsey Racing:
SOLID BUSHINGS KIT at LINDSEY RACING - Your Porsche Performance Parts Center
Later.
Gawernator 04-04-2013 08:48 PM
Anyways. You're still not addressing the fact that you can't change the front without matching in the rear without screwing things up.
billy mild 04-05-2013 06:55 AM
If you didn't read my previous post. I am currently only doing the front. I will get the rear after the front has been sorted. I have the front suspension, plus steering rack I need to do first. After that has been completed then I will move to the rear.
Gawernator 04-05-2013 10:51 AM
It's something that needs to be changed at the same time
Rasta Monsta 04-06-2013 10:42 AM
Give it up, he isn't listening.
