This doesn't look right...
Why is the rear shock absorber not flush up against the bolt? Is this right or is this another reason for me to hate my PO? I'm about to put konis on because these kybs suck!
Should I get new bolts? If so where can I find them? http://forums.pelicanparts.com/uploa...1365468180.jpg http://forums.pelicanparts.com/uploa...1365468264.jpg |
The bolt IS tight against the shock. You are seeing a metal sleeve (it's part of the shock) around the bolt. The sleeve is longer than the end of the shock to allow for movement of the shock. Some shocks have longer sleeves than others.......
I was confused because I had seen others that were flat up against the bolt. |
Why the rust if you're in CA?
Your axles are pretty rusty. Sway bar, trailing arm connection. Clean up those shock bolts, make sure the rest of them isn't rusty. Replace that CV boot too. Otherwise your CV joint is going to be ruined (it may already be). |
I'm from Michigan and got it shipped out here when I moved. What happens if the CV joint gets ruined? |
You may be able to salvage the joint if it's recent. Michigan, the Mitten state! Just kidding. :D Take care! |
If you're looking for new CV axles I'll be pulling a set off an 87 S that are in good condition one of these days...
During previous ownership of my car, the boots exploded showering everything with grease. The PO replaced the CV joints, but never cleaned all the gunk. He proceeded to drive through gravel, and on country roads... etc .... Finally I got it all clean when I did the clutch. Some of the bolts were completely hidden by layers of muck.... |
And yes the mitten state. Oh how I miss it...NOT! Quote:
Pelican Parts - Product Information: 944-331-903-00-M60
10 bucks a boot. Screwdriver and plastic scraper shaves off the big stuff, and Varsol with a little brush will clean the rest. Pretty time consuming, but worth doing. It makes maintenance easier, and the car will looks a lot less like an 80's beater. |
Its not a CV axle. Its a CV joint on the end of the axle, actually 2 CV joints -- one on each end of the axle.
And if they actually BREAK, which they do sometimes, like when all the grease comes out because the boot fails, the end of the axle can flail around in there and break stuff... |
Buy once cry once
If the boots aren't torn and the joint isn't making any noise, I wouldn't worry about it. Go fix something else.
The boot in the photo is cracked and destroyed and it looks as though it's been that way for a while. At a bare minimum I would pull the axle, clean, and repack the CV joint before putting on a new boot.
Hi Mike..The ebay item looks fine to me, I would buy one. So, unless someone else has had a bad experience with that seller or item, I think you're pretty safe.
Have fun fitting them...and always wear disposable gloves when handling really greasy parts!! ;) |
Call travis at rennbay. Best prices and service imo.
IIRC the VW rabbit/Golf uses the same one?
When you get them off and all cleaned up check for any wear before you go and repack 'em. You'll need a 8mm 12 pt "cheesehead" tool to get the bolts off, some good degreaser and some CV joint grease as well. Its also been said that its you should tighten the bolts back up with a torque wrench so factor all of that into your cost as well.
KC |
I've heard something about switching the joints to extend their lives. Would this be switching the outers with the inners? And how many ft lbs? 32? |
I think I switched mine left for right, inner for outer should do the same thing.
Clarks garage instructions with torque specs. CV Joints - General Information, Removal, Installation, and Maintenance |
Or some other combination. |
I can't remember, just flip them so that they spin the other way say from CW to CCW.
Dont worry people, I bought the CV boots!
