-   -   What coolant do you use? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/744511-what-coolant-do-you-use.html)
Volhv 04-13-2013 09:18 PM
I know it should be phosphate free, but what about silicates?
I currently use STP extended life. The specs for it say it should be fine.
What's a better solution....preferably something readily available.
Gawernator 04-14-2013 02:06 AM
Not sure if you have the same stuff, but Prestone green coolant, phosphate and silicate free,and it's like half the price of Pentosin xD
princej 04-14-2013 04:20 AM
zerex G-05
another option.
ernie9944 04-14-2013 05:23 AM
Same here Prestone extended life.:D
Rasta Monsta 04-14-2013 08:01 AM
Sweet, is this another thread where everyone is gonna get pissed off?
I used Zerex G04, recently switched to Pentosin NF.
gtroth 04-14-2013 06:23 PM
I will only use blue Pentofrost NF which I get at Napa. Here is the spec sheet
Audi/VW ZVX 237 105 = Pentosin G001100 = Pentosin NF = G11 = blue.
See blauparts article if interested.
[/QUOTE]
RedBaron 04-14-2013 06:40 PM
G11 Coolant (Pentofrost NF). If you decide to use it, fill the car with distilled water first and run it up to temperature and then flush it out. It will remove all the old coolant/gunk. Make sure you don't get the G12 (SF) coolant; if you mix NF and SF it makes a jello-like substance.
alan6272 04-14-2013 07:31 PM
I'm not going here LOL
Gawernator 04-14-2013 07:34 PM
lol... brake fluid anyone?!
9FF 04-14-2013 08:02 PM
Sweet, is this another thread where everyone is gonna get pissed off....
Lol, you are all so wrong, omg green is so last century. I use this stuff because its pink ;)
http://i1196.photobucket.com/albums/...pse6bc1971.jpg
...btw it is phosphate & silicate free and available everywhere.
Gawernator 04-14-2013 08:07 PM
It's like the same ****!!! lol wtf!
v2rocket_aka944 04-14-2013 08:36 PM
the one that's on sale.
Volhv 04-14-2013 10:32 PM
Shouldn't be. That's just reserved for oil, not all fluids.
I'm thinking of switching to something else.
The STP I use is VW TL 774D approved (G12), and Dexcool. My water pump started leaking shortly after I installed it.... I put the gasket on dry. I want to blame the coolant, since it did not leak when I had just distilled water in it.
Hopefully the Canadian NAPA has Pentosin.... that looks to be the most popular choice.
Volhv 04-15-2013 05:38 PM
Bought some premixed (all i could find) Zerex G05, and a loads of distilled water so I can flush the whole system of the STP. Maybe I will keep the water in there till I am ready to put the bar on the road....... Water has a harder time leaking opposed to coolant..... cut will cause corrosion, and freeze.
JAXTURBO 04-16-2013 12:17 AM
Zerex here...
