What coolant do you use?
I know it should be phosphate free, but what about silicates?
I currently use STP extended life. The specs for it say it should be fine. What's a better solution....preferably something readily available.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
AFM #725
Not sure if you have the same stuff, but Prestone green coolant, phosphate and silicate free,and it's like half the price of Pentosin xD
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
zerex G-05
another option. |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Toofah King Bad
Sweet, is this another thread where everyone is gonna get pissed off?
I used Zerex G04, recently switched to Pentosin NF.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I will only use blue Pentofrost NF which I get at Napa. Here is the spec sheet
Audi/VW ZVX 237 105 = Pentosin G001100 = Pentosin NF = G11 = blue. See blauparts article if interested. [/QUOTE]
1995 993C4 guards red 1988 944S alpine white |
G11 Coolant (Pentofrost NF). If you decide to use it, fill the car with distilled water first and run it up to temperature and then flush it out. It will remove all the old coolant/gunk. Make sure you don't get the G12 (SF) coolant; if you mix NF and SF it makes a jello-like substance.
I'm not going here LOL
1983 944 ,1983 V-65 magna catalina22 sold baja ski boat sold my toys |
AFM #725
lol... brake fluid anyone?!
![]() ![]() ...btw it is phosphate & silicate free and available everywhere. |
AFM #725
It's like the same ****!!! lol wtf!
the one that's on sale.
I'm thinking of switching to something else. The STP I use is VW TL 774D approved (G12), and Dexcool. My water pump started leaking shortly after I installed it.... I put the gasket on dry. I want to blame the coolant, since it did not leak when I had just distilled water in it. Hopefully the Canadian NAPA has Pentosin.... that looks to be the most popular choice.
Bought some premixed (all i could find) Zerex G05, and a loads of distilled water so I can flush the whole system of the STP. Maybe I will keep the water in there till I am ready to put the bar on the road....... Water has a harder time leaking opposed to coolant..... cut will cause corrosion, and freeze.
Zerex here...
86 951 blk |
