-   -   Won't start below ~60F & unknown connectors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/744606-wont-start-below-60f-unknown-connectors.html)
elceser 04-14-2013 01:19 PM
1983 944 won't start below about 60F. When it runs it vibrates. What is this "orange" connector at the and the other unplugged one. I'm sure that this is a temperature sensor issue related to this connector, but can't find it anywhere.
http://forums.pelicanparts.com/uploa...1365970748.jpg
elceser 04-20-2013 04:18 PM
I know that the "orange" connector (single wire) is the O2 sensor and the two pronged plug is a oxgen sensor heater.
Why does the car not start if the outside temp is below about 60F???
Gawernator 04-20-2013 11:57 PM
Not sure if the DME temperature sensor would keep it from running at all
mytrplseven 04-21-2013 09:06 AM
The DME temp sensor is on the front of the engine and has a blue connector. Cheap and easy to replace. Also, that O2 connector looks suspicious. Is it connected, broken or what?
