Lear35A's Avatar
Heater duct gaskets - NLA
When I took the instrument cluster out to work on the voltmeter in my 968, I saw that the gasket(s) that seal the heater/AC air outflow to the ducts that go into the cabin had pretty much turned to foam powder. It looks to me in the PET, Illustration 813-00, that there are two parts involved, positions 10 and 11 (and maybe 11A. I have no idea what the difference is.). Part numbers 94457220100 and 94457216201. A call to Sunset shows these are No Longer Available from Porsche and the system shows no NOS at any dealers.
Mine were so deteriorated I couldn't use them as templates to make something up out of weather stripping or something like that. Has anyone else seen this, worked on this, fixed this??? It appears that these parts are also used on all the older 944 models going back to 1985. Ideas?
Lance
'94 968
Old 05-28-2013, 10:01 AM
Triple T
Try ***********
FOAM PLSTC SEAL - G94457220100
Old 05-28-2013, 12:55 PM
9FF 9FF is offline
9FF's Avatar
Just use 1/4in high density pvc foam, comes in rolls at any Home Depot, look in door and window weatherproofing, it's better than the OEM foam they used in the 80's.
I wouldn't shop at Auto Atlanta if they paid me, I wouldn't trust them to wipe my ash and do it right.
Old 05-28-2013, 01:10 PM
AFM #725
Gawernator's Avatar
Auto Atlanta is risque but I have ordered three times from them with moderate success.. don't like them though.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-28-2013, 01:27 PM
I would do as 9FF has suggested.
For the record, if a regular Porsche dealer can't get something like that then Auto Atlanta won't be able to get it new either. Their system only updates things as NLA when someone orders it and their dealer says it's NLA (just like pelican)
Prices alone should keep people away from auto atlanta. Sure there are horror stories around (none of which I've been involved in) but when it comes down to it they are a good 10% higher than pelican or the dealers.
Do you fly Learjet's?
Old 05-28-2013, 02:42 PM
porschetub's Avatar
Jrboulder,correct on AA ,have you seen their ebay listings,some parts are the "best in the world" and very "rare" and parts for the "concourse owner" ,amazing BS.
There feedback is ok but will that last
To the op best to make the parts our buy new from a dealer
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-29-2013, 12:02 AM
Lear35A's Avatar
Thanks for the tips. One reason I wanted the oem gaskets is that I am not really sure where the seal should be. My gaskets were so deteriorated I can't be sure. I guess I'll just have to get in there and figure it out.
Yes, I have an LRJET type rating and was flying them for a few years. More recently Hawker 800s.
Lance
'94 968
Old 05-29-2013, 05:08 AM
Triple T
I was going to suggest the cut your own gaskets using the old ones as templates routine!
But a google search turned up AA, and that was easier then typing...
Thanks for the heads up on AA.
Terry
Austin
3:16
Old 05-29-2013, 08:15 AM
You might want to post in the used parts section. Maybe someone has some you could use as a template for new ones.
Old 05-29-2013, 08:35 AM
AFM #725
Gawernator's Avatar
I was able to get the "NLA" 944 turn signal lenses, new, from Auto Atlanta on eBay, and nobody else had them.
Old 05-29-2013, 08:41 AM
