Waterpump?
So I have 85.5 944 that I got for free. The car was running and being drivin by my cousin but he parked it and it has been sitting for a couple years. I have been told by a bunch of people I need to change the water pump and timing belt/ rollers before thinking about trying to start it up. I would like to get this thing running at least. What I need to know is which water pump and which timing belt kit do I need? The reason I ask is because some of them say they are for my correct year but others say if you are replacing the waterpump on an 85.5 944 you need to get the 87 pump with the can chain guide and if you gut that one then the pully size changes so you have to get a different belt kit? Super confused a little help would be great!
All you have been told is correct,but before you race in and spent $$$$$,pull the front covers and check the belts,if they aren't oily, dry,worn,loose or cracked you can run it up.
If you did change the pump you would replace what you have ,your car should have the upgraded one anyway,if not you can buy the upgrade kit. PLEASE dump the old fuel and check the condition of your fuel lines before you turn the key. Best to get it running and driving before you spend,it may not be what you want or like or could just be a money pit. If the car is a good one theres a lot of stuff to refresh if its been sitting,that you can find out on HERE. Report back,cheers
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
A free 944, wahoo!
If your plan is to get the car running and then evaluate it I would change out just the timing/balance shaft belts. They don't cost much and it doesn't take that long. You can inspect the rollers when changing the belts. You don't want the old belts to break while you're working out the bugs and if you decide to sell her, you don't want the belt to break while someone is looking at it or taking it for a test drive. If you're committed to keeping the car and you're up for spending the cash, do the complete FOES. There's also a list of things to go through when waking up a car that's been sitting for awhile. Good luck with your car. Bruce |
The OP can read up/ask and make a discussion,if he has a patchy past history on the belts or servicing fine but it appears he just wants to get it running. Too much belt change "must do" cr#p goes on with these cars IMO,after all they aren't made of string,cheers.
Proprietoristicly Refined
I commented in color
Pelican Parts - Product Information: 944-106-313-00-M260 If the car still has the OEM old pump and you change it to the "updated" pump, you will also have to get these parts... Porsche 924S/944/968 Water Pumps & Hoses - Page 1 GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Frankly my dear....
To be honest, a lot of poor advice can be given by owners who have never experienced a belt failure, with these engines it is always an expensive and time-consuming exercise to get them operational again. However, if you give everything a good examination before starting the engine, you should be OK, but replace as soon as possible and don't think you will always be able to dodge the bullet...not being dramatic but realistic here from personal experience. All the best and good luck with your 'free' 944 ![]()
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
