944paige
Send a message via Yahoo to 911paige
Need some help.
Hi guys I just picked up a 944 track car. Came with the cam housing off of the car P.O said he took it off to check the valve springs I suppose. My question is in order to reinstall beside the gasket do I have to do any thing else I checked the cam and its workings appears to be fine do I just sit it with the new gasket and put the screws in and torque them down. I've never done this before I know I have to make sure my timing marks are good before attempting to crank her up. But need advise or a human to help me. Thanks
Old 05-22-2013, 11:27 AM
For the installation of the Cam Housing. Note: There is no sequence as to how the bolts are tightened, but using the "Star" pattern is suggested to draw the cover down evenly.
http://www.clarks-garage.com/shop-manual/cam-02.htm
http://www.clarks-garage.com/shop-manual/repair-procedure-index4.htm
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 05-22-2013, 08:38 PM
944paige
Thanks. Correct me if the cam housing stays up from the head a bit because it has to be compressed easily and evenly right? I thought it was going to fit flush but that's not the case.
Old 05-22-2013, 08:41 PM
GreenWater's Avatar
Correct. The cam housing won't sit flat until the screws are tightened. I would be wondering why the PO took it apart.
Is it your first 944 or have you just never done engine work like this.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 05-22-2013, 09:14 PM
944paige
It's not my first I've just haven't gotten this deep into them but the P.O said he removed it to check the valves or valve springs. But he gave up on it, and let it sit for a few years, he said when it reved up to 5 or 6 thousand rpm it would shut off something like a rev limiter, but not quite. I just want to get it back together and run it.
Old 05-22-2013, 09:21 PM
1983 944 N/A
POPS 83 944's Avatar
There is some info on this post
leaking Cam tower
And here is photo of how to hold the lifters in the housing (not my photo, borrowed to help a fellow 944 owner out)
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 05-22-2013, 09:24 PM
GreenWater's Avatar
It might be a good idea to take the head off and check things out. The PO felt the need to take it apart so there must be a reason.
84 944
Old 05-22-2013, 09:41 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
It takes an allen-socket head and you may have to grind down the head of the socket part so it'll fit into the holes in the cover. Be careful it doesn't come off when you withdraw it.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-23-2013, 11:57 AM
