Patrick
pfarah's Avatar
AC problem
So I have a dumb question that needs clarification.
Does my 84 have an orifice tube or is the expansion valve the same thing?
Thanks!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 05-30-2013, 10:47 PM
expansion valve is what you have
Old 05-31-2013, 03:56 AM
Patrick
pfarah's Avatar
Thanks.
I take it that in order to access the valve, I must remove the glove box and knee panel and remove the blower fan assembly... Perfect in this 90 degree heat!
Old 05-31-2013, 05:54 AM
Just thinking out loud
mattdavis11's Avatar
Just curious as to why you need to get at it?
91 FJ80
84 Ram Charger (now gone)
Old 05-31-2013, 06:58 AM
Patrick
pfarah's Avatar
Sorry for the delayed response...
I took the car to a buddy of mine that knows AC very well and he determined that the system is clogged. I've already replaced the drier and few other components so the expansion valve is the only other component remaining. I hope to work on the car this weekend and would like some instruction once the knee panel is removed. Thanks!
Old 06-03-2013, 07:00 PM
Motor Head
You can have any ac certified person check to see if the expansion valve is bad. The difference in pressure from high side to low side will be off from where it should be. Too high of pressure on high side and too low on low side means plugged. Too equal of pressure means the valve is open and not closing all the way.
2013 Ford Focus SE - 5spd mtx, Spectre filter, Unleashed E85 Tune, much more to come. - DD
2011 Ford Flex - Catless Downpipes, lightweight Mustang Motorsport 20x8.5 wheels, 3 bar MAP, Unleashed 15 psi tune - SOLD
1986 944 Turbo - 100K mile cream puff - FOR SALE
Old 06-05-2013, 12:05 PM
Patrick
pfarah's Avatar
That's what I did and, yes, he determined that the valve is clogged. You are on point with the gauge readings; I'm not an AC guy by any means, hence, the second opinion.
Old 06-05-2013, 06:39 PM
