idle too high and shearching
what should I be looking to adjust to stabilize the searching idle?
Old 06-03-2013, 09:57 AM
Vacuum leaks.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 06-03-2013, 10:57 AM
Proprietoristicly Refined
John_AZ's Avatar
+1^
If this if for your '83 944, I would check for a vacuum leak.
Change the vacuum lines and all hose clamps.
Do the "soap Bubble" test perfected by mytrplseven:
vacuum system test.....soooo easy
You idle stabelizer is also a problem on the early cars.---Oil and grime gets into the unit but not easy to clean as the late type. Unit is expensive and may not solve the problem.
Rebuild the TB with a kit from Bruce Arnn at arnnworx.com
Throttle Body Reseal kits for Porsche
Unplug the O2 sensor and see if it stops searching.
Change the engine temp and coolant sensors.
Do a compression test and leak down test.
Remove the intake and change the AOS seals and all hoses under the intake.
Rebuild the injectors.
More? Sure, just a few to start with or eliminate the areas you have already done.. I am sure I missed a few.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-03-2013, 11:00 AM
Back from Beyond
John, do you mean AAV and not idle stabilizer? A stuck Auxiliary Air Valve will cause hunting idle. A pain to get to with the intake on the car but it can be cleaned.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-03-2013, 01:10 PM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
I would also do a compression test. If you have worn or broken rings and oil is choking the engine, this will cause the idle to fluctuate and surge up and down. If you do the compression test and one or more of the cylinders are low, have fun rebuilding the top end.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 06-03-2013, 01:49 PM
John_AZ's Avatar
Slam you are correct--my part name error--part #9.
How do you test an early Auxiliary Air Regulator?
J_AZ
Old 06-03-2013, 03:11 PM
Patrick
pfarah's Avatar
I found a way to remove the Aux Air Regulator without taking off the intake. You have to remove a few other parts but after about three times, I've got it down pretty well. Take a look at the intake manifold from the front of the engine bay, remove the j-hose and associated vacuum hoses that connect to it. You can use an extension to remove the two bolts that secure the AAR; be careful of hose 13 and 15 (shown on the diagram above) because they will crack/break if original. I must tell you that replacing hose 15 can be a bear. Once all the hoses have been loosened, simply rotate the AAR 90 degrees and shimmy it toward you. If the valve is original, you may wish to replace rather than clean it. Cleaning the valve only works for a while (ask me how I know). Replacing the AAR transformed my 84 into a well-oiled machine, that is until the next series of problems arose. Anyway, PM me if you any specific questions and good luck!
Patrick
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 06-03-2013, 06:55 PM
