-   -   Sway bar bushing replacement (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/756921-sway-bar-bushing-replacement.html)
cro-cro 06-19-2013 04:32 PM
The other day I heard a little thumping in the front left suspension. I looked under and saw the sway bar bushing was not all there. I've tried to find something online about what it takes to replace and haven't found anything. I figured it would be worth it to replace both at the same time. What all takes place in replacing the sway bar bushings?
Gawernator 06-19-2013 04:42 PM
Take off bar, cut off old bushings, slide on new ones (I used silicone for lube) lol
cro-cro 06-19-2013 05:03 PM
Do I need to get a caliper to figure out which set of bushings to get?
Gawernator 06-19-2013 05:19 PM
Better safe than sorry if you aren't sure of the size
cro-cro 06-19-2013 05:24 PM
It's tool time.
9FF 06-19-2013 06:58 PM
You don't need any tools. Wrap some masking tape around it and mark off the circumference. Take the tape off and measure with a ruler. The size (diameter) of the sway bar = circumference you just measured / 3.142
Gawernator 06-19-2013 09:13 PM
A ruler is a tool :p
Rasta Monsta 06-19-2013 11:07 PM
http://i124.photobucket.com/albums/p...iley/rotfl.gif
HA or you could slip an open end wrench or two over the bar!
So is a calculator!
