Sway bar bushing replacement
The other day I heard a little thumping in the front left suspension. I looked under and saw the sway bar bushing was not all there. I've tried to find something online about what it takes to replace and haven't found anything. I figured it would be worth it to replace both at the same time. What all takes place in replacing the sway bar bushings?
AFM #725
Take off bar, cut off old bushings, slide on new ones (I used silicone for lube) lol
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
AFM #725
Better safe than sorry if you aren't sure of the size
You don't need any tools. Wrap some masking tape around it and mark off the circumference. Take the tape off and measure with a ruler. The size (diameter) of the sway bar = circumference you just measured / 3.142
AFM #725
A ruler is a tool
![]() Quote:
Toofah King Bad
![]() HA or you could slip an open end wrench or two over the bar! So is a calculator!
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
