-   -   tuning a 944NA with an Abaco sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/757422-tuning-944na-abaco-sensor.html)
nynor 08-05-2013 08:56 PM
my take is that you need to map that voltage output to mirror this image:
http://forums.pelicanparts.com/uploa...1375761315.jpg
ritter4242 08-06-2013 07:21 PM
The only problem is that is for the 84, I'm not running it as an 85.5, and I don't know what values to correspond the voltages to... my MAF is in either kg/hr or lbs/hr... not the m^3/h that the original AFM used. So not only is there a conversion factor but there is the matter of the late AFM/DME combo not having a reference like the early AFM/DME combo.
http://forums.pelicanparts.com/uploa...1375842053.jpg
nynor 08-06-2013 07:51 PM
regardless, the map you posted does not correlate to either. the reason i'd try the early curve first is because of the flow rate matching the voltage curve. if that doesn't work, i'd try the linear map of the later AFM/DME.
actually, now that i am thinking about it. you have a point. i'd use the later map first and see what happens. the DME is expecting that linear map corresponding to the logarithmic increase of airflow. again, the map you posted in #3 is obviously not quite right and trying the linear map is not going to hurt. save both files and start the playing.
ritter4242 08-08-2013 08:16 PM
crap....
http://forums.pelicanparts.com/uploa...1376018171.jpg
nynor 08-08-2013 09:27 PM
coolant? what happened?
actually, that looks like piss....
ritter4242 08-09-2013 03:00 PM
Yeah its coolant, The damn car overheated... /: so tuning has definitely taken a back seat to this, I had changed A LOT on that voltage curve, so hopefully I have it running again soon!!
nynor 08-09-2013 05:10 PM
how bad did it overheat? from where did the coolant escape?
ritter4242 08-10-2013 04:48 PM
I don't know exactly how hot it was, I was in front of the car when this happened, and had my dash disassembled. /: I'm pretty sure it came out of the tank, but from what I'm hearing in the other thread I started since it over pressurized so quick I blew the head gasket.. I was using Dex Cool...
nynor 08-10-2013 07:45 PM
well, maybe. only one way to find out.
ritter4242 08-14-2013 03:22 PM
ok i did a compression check 180 190 190 180 :) so its the cooling system...
nynor 08-14-2013 06:59 PM
could still be the head gasket. but i bet the radiator cap wasn't on all the way, or something.
nynor 08-14-2013 07:00 PM
we need another video, BTW. this is a cool project.
ritter4242 08-14-2013 07:56 PM
20130810 182204 - YouTube
so... there's the new video, lots of swearing... lots of problems...
lol a few of them fixed :)
nynor 08-14-2013 08:29 PM
your thermostat is stuck closed.
nynor 08-14-2013 08:30 PM
or it is in there backwards.
the car sounds like it is running good, so that is a plus.
ritter4242 08-14-2013 08:35 PM
Well idk if you are keeping up with my other thread on the matter, but I need to sort out a fuel injection issue, so I'm going to rob my parts car of; fuel injectors, rail, thermostat, and a water pump, as it is most likely fried.. This is all off of an 85.5
nynor 08-14-2013 08:37 PM
if i can peer pressure you into one thing, well two, get a NEW thermostat and, unless the other waterpump is new, a NEW waterpump. for sure a new thermostat, though. those things are cheap.
nynor 08-14-2013 08:40 PM
oh, and you have to pull the belts to get to the waterpump....
new belts and rollers.
i know, $$$.
ritter4242 08-14-2013 08:41 PM
Haha well that's the problem, this all started (the overheating) when I replaced the original.. I'll pick up a new one and test both the new and the old side by side, I'm going to pull the water pump out of the 85.5 and just rebuild it, a new one runs about $400 last I checked..
ritter4242 08-14-2013 08:43 PM
Well I might as well get new hoses while I'm at it... Lol and it needs new rollers and belts, I'm almost positive the pump is seized, horrid screeching when it idles super low from the 3 cylinder issue...
