-   -   tuning a 944NA with an Abaco sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/757422-tuning-944na-abaco-sensor.html)
ritter4242 06-22-2013 04:47 PM
Well I got into the MAF is better than AFM hype.. and man do I have second thoughts. I mean the numbers were good, it made sense, and the AFM is almost 30 years old now. So I went out and got an Abaco 85mm Quad sensor.
Well the car runs, it just doesn't run.. right.. I get to 3000 RPM very slowly and then it kinda sits there and chuckles. If I put the pedal to the floor it shudders and doesn't accelerate. I'm not a big car guy and I've been learning the ropes on this car. I think I may need to replace injetcors, spark plugs, fuel lines, fuel rail etc.. but I'm pretty sure its the air flow sensor.
So my question is does anyone have one of these that turned out well? should I just sell it to one of the 951 guys and just get a rebuilt AFM? I really want to keep the Abaco sensor because my fuel economy is well.. it hasn't dropped below 30 very often. So it IS working, just not the way it should. I know the car can haul. I mean it hasn't been THAT long since it was driven with the AFM, but it sure isn't doing what I know its capable of.
http://forums.pelicanparts.com/uploa...1371944563.jpg
AaronM 06-22-2013 06:44 PM
Are you sure you set up the MAF properly? If the car was running fine with the AFM then it's probably an issue with the MAF.
The early and late AFMs have different signal patterns, so if you have an early car you can't run the same MAF settings as a later car. From what I can tell, none of the supplied maps for the Lindsey Abaco MAF kit will work with the early DME.
The early cars have an AFM that uses an unregulated 12v input voltage (minimum 8v) and the output is nonlinear while the later cars use an AFM with a linear output and a regulated 5v (+/- 0.5v) input voltage controlled by the DME.
If you have an early car and are using one of the canned maps in the LR kit it looks like you're going to lean out massively as RPM climbs, which is in line with the symptoms you're seeing.
For more on the difference between the early and late 944 AFMs, I recommend here: Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
ritter4242 06-22-2013 07:12 PM
I have been assured repeatedly that I have the right file (from Dave Lindsey himself) that it is file #4 selector 1.
File #4 ----- 944 AFM(S1) | 19#(S2) ~ 944 8v AFM / MAF CALIBRATIONS
Anyway I know that it is the MAF sensor, I just thought there was a possibility that since it sat for three years that the fuel system might have taken a hit or the spark plugs could have fouled.
I am looking more for how to tune the car, is there a method for determining whether it is rich or lean? this is a screen shot of the MAF settings as they came from Lindsey..http://forums.pelicanparts.com/uploa...1371953540.gif
AaronM 06-22-2013 10:11 PM
The only way to be sure whether it's rich or lean is to check the tailpipe with an appropriate wide-band oxygen sensor.
I didn't see in your original post that the car has been sitting for three years. While gasoline is generally OK for up to 12 months, at 3 years I wouldn't trust the old fuel. Might be as simple as draining the tank/lines and running some fresh gas and fuel system cleaner through it.
Gawernator 06-23-2013 01:20 AM
No help here but cool 944... where is the front end from?
NBTF 06-23-2013 10:28 AM
Gawernator, Looks like the EVOII kit from Fiberwerks.
http://www.fiberwerks.com/evoIIred.jpg
ritter4242 06-23-2013 10:29 AM
Gawernator: its from Fiberwerks :) I love it!
Aaron: I used seafoam, I've changed the gas and it runs ok, I'm like 90% sure that the gas and subsequent systems in it are ok, it runs really rough on start, normally coughs itself out (its too rich) but after a few miles it warms up and runs fine at idle. So... this oxygen sensor.. where do I get one, how do I use it... any guides? :)
OH it also seems to be running really hot, I mean not overheating but you get out and can feel the heat through the hood (I can't get my hood liner to adhere) and its my understanding that running rich means running hot (experience from piloting small aircraft)
Thanks guys :)
Gawernator 06-23-2013 10:50 AM
Is it 1 or 3 wire O2 sensor? You can get both right here at Pelican but I got the Bosch universal heated sensor a lot cheaper off eBay (California car)
ritter4242 06-23-2013 10:52 AM
uhhhhhh... I have no clue... How do I use the sensor to tune the car? I don't even think my car has an O2 sensor anymore. I had to replace my exhaust from the header back.
Gawernator 06-23-2013 10:55 AM
Lol - so I just realized he was talking about a wideband sensor. Disregard what I was saying
ritter4242 06-23-2013 10:57 AM
haha thats totally ok x) so whats a wideband sensor?
petrolhead611 06-24-2013 02:51 AM
running hot is a result of a lean mixture
AaronM 06-24-2013 09:46 AM
It's the sort of thing you'd see at a dyno tuning station. When they hook up the car to the dyno they will also stick a probe in the tailpipe to measure the mix and make sure the car isn't running lean.
There are also wideband sensors you can buy to install with additional aftermarket gauges, but that would require being able to install the part on your own.
ritter4242 06-24-2013 02:54 PM
Is it really that hard to install the wideband sensor?
AaronM 06-24-2013 02:58 PM
Not really, but you'll have to be able to weld in a bung on the exhaust before the cat to get a reliable reading. Plus you need a place to mount the gauge in the car.
It's usually just easier to do a few dyno pulls and judge from there using the shop's tailpipe probe unless you really want to have a wideband gauge in the car.
ritter4242 06-24-2013 03:05 PM
well screw it why not! SO I don't have a cat, and I can run over to a shop to get a new bung thrown on (I've got a guy, does great work) What do I do with the sensor, like how do I read it, know its lean or rich? I'm gonna send my afm to abaco and get the right file to the sensor is working, and then I plan on tuning the ECU (DME?!) and getting a really nice setup out of it ;) So any recommendations on tuning systems for the NA? I don't want a new sensor (like rogue's setup) just a chip and computer program.
AaronM 06-24-2013 08:20 PM
You have to buy the sensor and gauge driver, then install it in the car. The (quality) kits I've seen run $200 to $250 not including a pod to mount the gauge in.
You'll need to know what air/fuel ratio you are targeting. Stoichiometric is 14.7:1 Higher numbers are leaner, lower numbers are richer. At idle or low-load cruise the gauge should read right around the 14.7 point. At WOT and full load turbo cars will drop into the 10-11 range, leaning out a little at by redline. NA cars will probably only want to drop into the low 12s under WOT full-load conditions.
My guess is that if the engine isn't even wanting to rev past 3,000 RPM, is running hot, and your fuel mileage is "great" you're probably going to see the gauge pegging out at its maximum (leanest) reading.
BisimotoJulio 06-25-2013 06:17 PM
A wideband sensor setup with gauge is a well worth investment to monitor true and accurate air/fuel ratios. I personally use an AEM Electronics wideband UEGO with Digital display gauge on all of my projects! Best of all these kits are accurate to 0.1 AFR and come complete with gauge, Bosch O2 sensor, weld on O2 bong, and wire harness.
If you are in need of one, I happen to have a handful of new units that I can let go for $155 including shipping to the Continental USA. Shoot me a pm for more information.
ritter4242 06-26-2013 02:58 PM
Well that settles it! So plan of action:
get O2 sensor
tune the damn thing
tune the DME
so the next hang up I have is how do I tune the DME? is there a chip and software that'll work the first try? (bit of sarcasm there) I will tune the MAF so its close to the original AFM and then try and tweak the MAF and the tweak the DME, I'm not looking to make a suped up racer, I would just like a little more performance out of my little girl :)
Bisimoto: that sounds great! so its the gauge, sensor, wiring. so just stick the thing on the exhaust, connect the wires, and turn the car on? If you could upload a picture of the kit that would be awesome :D I'll send you a PM
AaronM 06-26-2013 07:30 PM
get O2 sensor
tune the damn thing
tune the DME
To be clear, in the case we're talking about here you're mostly just checking to see if you're running lean or rich to get a baseline for what to do next.
The MAF kits work by emulating the signal that the DME expects from the original AFM. Theoretically you can do that by looking at the graphs in the link I already provided. The wideband O2 sensor and gauge just help you know what's going on if something's off a bit.
If you've done any modifications to your car other than the MAF and haven't changed out the DME chip, that could very well also be causing your problem because you need to have a new chip that takes into account the modifications you've done too.
ritter4242 06-27-2013 08:13 PM
Well all I've done is the vacuum lines, and I don't really think that'll do much! is there a kit or something that is recommended for the NA?
ritter4242 08-03-2013 06:32 PM
Alright gents, so this is whats going on, so I think its too lean all the way up? the afr isn't consistent. Do I need to let it run for a bit before I start making measurements
20130803 184721 - YouTube
nynor 08-03-2013 08:59 PM
yeah, that 18.0 is bad. i'd probably want to be seeing numbers around 13.7 for normal driving and lower for hard acceleration. you are going to melt something, if you keep running it that lean.
ritter4242 08-03-2013 09:01 PM
fuuuuuuuuuuuck.... well I'm glad I'm not driving it anymore... I have plenty of time tomorrow to fiddle with it
nynor 08-03-2013 09:01 PM
when you let off the throttle, you will see the numbers climb, that is because the engine is still turning fast, but you aren't on the throttle to give it gas. this is normal.
those numbers above 15 when hitting the throttle are not normal.
is the MAF supposed to have an O2 sensor input?
ritter4242 08-03-2013 09:02 PM
nope! its an abaco, part of the problem is it doesn't pump out enough volts, so I'm going to have to screw out the plastic bolt behind the pedal to stop it from over opening .. so 14s at idle, and 12's at wot,15s on close?
ritter4242 08-03-2013 09:04 PM
I plan on doing an AEM EMS... but I don't have the money or the time, and kinda want the experience
nynor 08-03-2013 09:05 PM
this could be a fuel delivery problem, also. i'd be for checking the fuel pump, per the instructions on clarks garage Clark's Garage Home Page. if that checks out, i'd check the injectors, especially if they sat for that long. if that all checks out, THEN i'd start playing with the tune on the MAF.
nynor 08-03-2013 09:07 PM
enough volts for what? an O2 sensor provides the voltage to give the MAF a signal. i bet the wideband you have can send the same signal. i know mine can, as i have to hook it up for emissions.
AEM EMS? not sure what that is.
edit: i googled it. engine management system.
what is it that you think you are going to get out of this, over the stock AFM?
ritter4242 08-03-2013 09:07 PM
hmmmm
well i'll have to give it a looksie, been looking for a reason to upgrade to Lindsey racing hardware :D
ritter4242 08-03-2013 09:12 PM
well the MAF is giving me faster revs when it works, and volts as in the MAF isn't giving the same range the AFM. its only like 5 volts and its supposed to give 6 or something. so I could program the EMS to understand the MAF and get a better running car.
The AFM provides a TON of resistance to the system.
nynor 08-03-2013 09:15 PM
oh, and on deceleration, that number will climb. hard deceleration, going downhill with no throttle, for example, it will probably be 17 or higher.
ritter4242 08-03-2013 09:16 PM
ok, I won't worry about the numbers when decelerating :)
nynor 08-03-2013 09:16 PM
it is supposed to give six volts, but lindsey racing sold it to work on your 944? i find that confusing.
nynor 08-03-2013 09:20 PM
right. my wideband maxes out when decelerating hard. >17 for sure.
ritter4242 08-03-2013 09:24 PM
I got the sensor from Lindsey, I knew it wasn't plug and play, part of the problem is the DME requires Xvolts and the sensor give Yvolts, that difference meaning I can't hit WOT completely. I want to upgrade my fuel system to lindseys rails. the MAF is ment to be used on heavily modded cars. like 951's
nynor 08-03-2013 09:32 PM
is the MAF for later 944's and yours is an early?
ritter4242 08-03-2013 09:35 PM
the maf is universal, theres the problem...
nynor 08-03-2013 09:37 PM
yes, but is yours an early DME? maybe it would work with a late DME. IIRC, the early DME is expecting 8V from the AFM. let me research that for a minute.
ritter4242 08-03-2013 09:39 PM
yes its early, they both require the 'wrong voltage' and the sensor is ment to be set up with a custom DME/EMS
