P944GUY's Avatar
Pics of my engine rebuild
After spending some serious time and money my engine is just about ready to be put back in the car...
88 924S engine block
Steel sleeved cylinders-previous owner did that
Custom J&E pistons-101.50mm
Compression 10:6:1 (euro spec) flat top pistons, originally was 10:2:1
All new bearings, 968 external oil cooler
Rebuilt head, new head studs..set at 73 mm
Polished crank,
Some great pics if you don't know what the inside of your engine looks like !!
Beer Cigars and a 10mm socket...
Old 07-06-2013, 08:52 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Very cool! I love the look of a shiny new engine.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-06-2013, 08:58 AM
P944GUY's Avatar
Yes..I did some very time consuming aluminum polishing...balance shaft covers, oil pan, motor mount brackets ..lots of cleaning..I bought the car here in Phoenix, but it originally came from near Oakland CA, and had a lot of salt water air corrosion on the aluminum parts
Old 07-06-2013, 09:03 AM
P944GUY's Avatar
I had the engine block cleaned and bored-honed at Lindsey Racing..shipping the bare block was about $80 each way..I should have polished the block with my dremel and a wire wheel!!
Old 07-06-2013, 09:04 AM
9FF 9FF is offline
9FF's Avatar
Very nice, thanks for sharing. Did you by chance fly cut those pistons to clear the valves fully open at TDC or are they stock cut?
Old 07-06-2013, 10:48 AM
P944GUY's Avatar
Not sure what fly cut means..the pistons are cut stock I guess...look at the pictures of the pistons..they are cut for intake-larger cut and exhaust-smaller cuts in the tops of the pistons...Mike at Lindsey racing ordered them for me
Old 07-06-2013, 12:46 PM
I'm jealous, my oily block is no where as clean
Old 07-06-2013, 02:22 PM
AFM #725
Gawernator's Avatar
Awesome, P944GUY!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 07-06-2013, 02:48 PM
porschetub's Avatar
What are your plans for the head? my research indicates good gains in that area.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-06-2013, 02:56 PM
Those should stock-type reliefs for 1mm clearance under normal operations.
Not enough thickness on the pistons to cut deeper reliefs to clear valves in event of timing-belt failure. Ends up needing a pocket 5mm deeper than the bottom-edge of the piston. Also the loss of compression due to larger combustion-chamber volume negates going from 10.2 to 10.6. This model shows cuts needed on 9.6 compression pistons; hole through piston would be even larger with 10.6 pistons.
Old 07-06-2013, 03:05 PM
9FF 9FF is offline
9FF's Avatar
Quote de 9FF
Those are custom, not stock 10.6 and the pockets must be deeper as they don't have the center dimple of stock 10.6
Being custom you could specify more depth at the top to allow maybe 10.2 with clearance for valves.
OP, fly cut pistons is what you have, it's the cut outs for the valves in the piston tops. I was just asking if you had them cut deeper to ensure there is no valve to piston contact if the belt breaks.
Old 07-06-2013, 03:25 PM
Proprietoristicly Refined
John_AZ's Avatar
Originally Posted by Gawernator View Post
Awesome, P944GUY!
+1
Jeff,
Thanks for the pictures.
Just great work!
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-06-2013, 05:40 PM
