Removing Steering Wheel w/ airbag
Would someone be kind enough to advise how to remove the steering wheel on my 1989 944S2. It has an airbag, so I am a little doubtful of the procedure. I want to discover the reason for the squeak in my steering wheel (only when I turn left) and eliminate it.
Michael
Old 08-20-2002, 12:14 PM
AFJuvat's Avatar
First thing to do is remove all power from the airbag circut.
Warning: the aribag module does contain an explosive - handle with care and use common sense.
On the back side of the wheel, you will see a couple of torx bolts (can't recall if they are tamper resistant or not) - remove them and the airbag should come out - CAREFULLY disconnect the wires and set the airbag in a safe location.
Remove the wheel as normal.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-21-2002, 02:47 AM
JWest's Avatar
Air bag circuits often contain capacitors (energy storage). Let the sucker sit for a while after disconnectiing the battery - just to be safe.
Old 08-21-2002, 10:27 AM
951carter's Avatar
let it sit for 20-30 min. after disconnecting the battery.
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 08-21-2002, 06:00 PM
overkill's Avatar
Send a message via AIM to overkill
STEP 4: Install MOMO Steering WITHOUT AIRBAG! Dude, becareful with it, it will take your head off it it blows
{1987}944S - (SOLD).
Old 08-22-2002, 07:46 AM
