Mechanic punched my hubs! %@#(&$
Disclaimer: I am pissed so sorry for the rant...
Okay, I take my very nice condition '85 944 hubs to the local Porsche shop that my 911 normally goes to since I know they have done me right in the past. They say that knocking the bearings and races out is pretty easy and should take an afternoon. Three days later my hubs are ready, not a big deal but kind of disappointing. When I pick them up the guy says it took 40 minutes to get the races out... Hmmm, WTF is so hard about races? I just nod and accept it. Now to inspect the hubs... Those b@stards just plain old used a long punch to beat these races out!!! Not a press like I expected. Needless to say there are blemishes that I need to sand out with emory paper from where they got sloppy and dinged the race mating surface! To add insult to injury the cost was $68! If I want to F up my d@mn hubs I could have beaten them out with a punch at home! For FREE! When I was in the shop it was not such a big deal... But the more I stew on it the madder I am getting about it. Am I paying for some dope to learn? 40 minutes my a$$! Any insight on how long this should take and the PROPER procedure for removing 944 races? There were no prior dings in the race mating surface after years and years of use so there has to be a better way... Thanks,
FS: 1979 Porsche 911 SC FS: 1992 Volvo 960 Wagon potential sleeper V-8 project 1971 Chevy C-10 w carb 5.3 LS swap 1948 Spartan Mansion 30' travel trailer |
I think you are susposed to heat the hubs to 300 degrees F before pressing races in & out.
drew1 |
I took mine over to a friends shop and we drove out the old an drove in the new in about 5 minutes using a bearing driver. It looks like a rod with a washer bolted to the end. The washer is chosen to fit the bearing. Any shop that does brake jobs should have one. JC Whitney even sells them.
I cross posted this in the 911 forum as well since the hubs are very similar:
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=62065 Thanks,
Pillow,
Thanks for the link. Difference between 911 & 944 hubs: Bearings are same but there is a difference between wheel & disk mounting distance from bearings. The bearing guys discription in the link sounds like the procedure in 924 Shop Manual for 5 lug hubs. drew1 |
Hey Pillow,
Sorry to hear about your hub problem. You need to let the Porsche shop know you are dissatisfied with their work. Ask them for an adjustment on your bill. I bought my 944 from the OO who had all his work done by "professionals". Stripped screws, improperly installed parts, evan a failure to tighten the transmission drain plug, leading to very low fluid on a freshly rebuilt transmission! My opinion? An unfortunate number of these guys are hacks. I am a better mechanic than some of those guys, and I'm just a motivated amateur. |
I just did a brake upgrade and installed new bearings at the same time. I've always used a long punch to knock out the old races. Then take the old race, turn it over, and use it to knock in the new one.
Here are some pics of recent work. Turbo Brakes, Front coil-overs, caster-camber plates. Last edited by 944 LT1; 03-10-2002 at 05:14 AM.. |
Irrationally exuberant
I know this is a little late but...
I figure someone may come across this post while they are doing a search so I thought I would mark this "landmine" for the next guy. The bad news guy is pretty much all of us have already ruined our hubs...
This is from an old Rennlist post I think: Quote:
bearings
wacking them in and out is fine, jesus, it IS a chevy bearing!
that's right ,machined down to towlerances of a 55 chevy |
my method
What you'll need:
1 Duncan Hynes cake mix of you favorite flavour 1 of whatever the box tells ya you'll need to mix in with the other mix. 1 oven preheated to 350 deg. 2 hubs 2 new bearings and races Directions: preheat oven Throw yer hubs in oven. or if you like your oven, gently set them in mix the edibles as directed on box Pour into your favorite pan (I like bunnys) in about 45 min take out hubs (they may be warm) set oven to temp spec on box Knock yer races out with a G.D. Hammer, it's a car fer crissakes, not a puppy dog. If your carefull you won't touch the mating surface with your punch/chisel/screwdriver/nail just make sure they come out evenly Use a socket that mates up well on the edge and tap the new race in retrieve cake and hid it in the garage ask wife why she left the oven on finish your job and enjoy a slab of cake during your test drive I accidently intalled one of my races in backwards, guess I was thinking of cake. If you do this, you'll really wish you had not.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
hubs
a race driver works well for install,at least that's what cooter from hazzard county tells me
I wanted to be a race driver
I used to want to be Cooter. . .
Well, I really just wanted to date Daisy. |
bearing fit!
i dont think i'd trust the shop to do the job properly {heating the hub}. most would use small press, and put them in dry.
possible short-cut, for the shadetree mechanic, would be to get hold of some "dry ice", and leave the bearings in there for about 1-2 hours, then press them in. same as heating up the hub, except the intense cold of the dry ice, will make the bearings about 0.002, to 0.004 thou smaller, thus allowing them to go in easily, without removing any material. i do this with phospher bronze/ steel plain bearings, and ball-races should apply as well. good luck! |
