Weird electrical problem
When I start up my 89 S2, oftentimes the blower and windshield wipers won't come on until I switch on the headlights. I just need to switch the headlights on and off and then everything works. I figured this had to be a bad ground so I cleaned every ground I could find (the two above the bell housing, one by each headlamp, one on the driver's side front fender and the one in the trunk), but I still have the same problem.
Any thoughts?
________________ 1989 944S2 2004 Saab 9-5 Aero Wagon |
one of gods prototypes
There is another ground junction up in the drivers kick iirc, which is ground for the relays and such...
Brought to you by Carl's Jr. |
In the Fires of Hell.....
I think that this has more to do with the ignition switch than grounds. I have had this same issue, which comes and goes. Never tried the headlight trick, though.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Man, I HATE the electrics on these cars!!!
Automotive Necromancer
why?
I know! Why is it that my almost thirty year old electrical system has any problems?
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
