-   -   Tach works but the MPG dial only moves intermittently (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/762281-tach-works-but-mpg-dial-only-moves-intermittently.html)
uvachief 07-22-2013 11:06 AM
I've got a late 944 na 5 spd that has a working tachometer but the MPG dial sticks from time to time. When you pull up to a stop, it will generally kick on and start fluctuating. Use to happen once in a while. Now it is very common. Aren't they part of the same cluster? Why would one work but not the other.
GreenWater 07-22-2013 12:39 PM
So does mine. I haven't figured out what's causing it yet. Please let me know if you figure it out.
GreenWater 07-22-2013 12:43 PM
I just remembered that someone here said that it could be the gauge and that I should take the gauge out of the cluster and clean the connections. I think I did it? I can't remember now. But my gauge still doesn't work.
uvachief 07-24-2013 12:36 AM
http://forums.pelicanparts.com/uploa...1374651366.jpg
http://forums.pelicanparts.com/uploa...1374651388.jpg
GreenWater 07-24-2013 08:10 PM
Mine jumps around about 5-10 MPG. Interesting red gauge surroundings. Looks cool.
Gawernator 07-24-2013 09:24 PM
Your cluster looks sweet! I'd say try cleaning the electrical insides
uvachief 07-25-2013 02:58 AM
Took it out so many times working on odometer gremlins that I painted it red when I got ticked at it one day. Need to find a matching red shift boot cover.
Gawernator 07-25-2013 08:57 AM
Where did you get white needles? I'm sure Kyle/Greenwater could assist with your shift boot.. ^_^
GreenWater 07-26-2013 12:13 AM
I didn't even see the white needles. I like it. I will have to do that to mine next time I take it apart.
Two more things I just noticed. I don't remember seeing the VDO on my gauge surroundings.(middle bottom)
The second thing, what does it say on the bottom of the speedo?
Thanks Andrew, I was thinking the same thing. I CAN make you a red shifter cover. Check out the other covers we sell and let me know if you want a red cover. Shifter Covers Just PM me or email me. A red vinyl cover should be the same price as the black vinyl.($15)
I should start doing custom covers. It's easy enough and I've done them before. I will have to add that to the site. Thanks Andrew.
Gawernator 07-26-2013 12:37 AM
Looks to me like it says "WOW!" Haha, anytime. If only I had a carbon fiber shift boot... oh wait.. xD
uvachief 07-26-2013 11:20 AM
Hand painted those as well.
uvachief 07-26-2013 11:22 AM
It is a VDO cluster. I think it came out of a 968 actually. I'd like to get a red leather shift cover. Classic9Leather use to sell them but I no longer see them on their website. That or black leather with some sort of red leather stitching. I thik they use to sell them for $45. I'd pay that.
uvachief 07-26-2013 11:25 AM
Oh yeah it says WOW! Those are stickers but you sure cannot tell. I had other really bad ideas but didn't do them. Like at 88 mpg I was going to put B2TF for Back to the Future. At 100 I was going to put JAIL.
rhett 07-26-2013 02:24 PM
I like the optimism :D I think I would have put - Never!
^^ LOL - 88 mpg??? If only... :) .... perhaps 88 MPH?
uvachief 12-27-2013 12:27 PM
Odd...replacing the starter seems to have cured the stuck mpg needle.
Sent from my SCH-I545 using Tapatalk
cockerpunk 12-27-2013 12:31 PM
bad ground somewhere you fixed in the starter?
preludeofwrath 12-27-2013 01:28 PM
which cars received the mpg gauge? i don't hae one :(
GreenWater 12-27-2013 02:49 PM
The earlier cars have a mpg gauge, my 85.5 does, but my 87 doesn't.
GreenWater 12-27-2013 02:50 PM
I probably have a bad ground somewhere too, but my starter works fine.
uvachief 12-28-2013 12:18 AM
Manual - 86 has one. That is a late model. Automatics of course do not.
